    1979 dogge transvan messing up
    transvan
    transvan
    Number of posts : 1
    Registration date : 2014-03-28
    1979 dogge transvan messing up Empty 1979 dogge transvan messing up
    Post by transvan Fri Mar 28, 2014 4:27 pm
    Hi everyone.  The first thing that brings me here is I/we have had a 1979 sportsman dodge "trans van" with a 360 engine for awhile now.  For a couple of years one would have to :goose " the gas to get it past the flat spot at much more than an idle, but It ran smooth otherwise and ran nice and cool.  I replaced the carb but it did not help. The van would stall out while going down the road and generally refuse to restart.  Sometimes it would restart after it sat for a few hours.  I dickered with the timing a bit, to no avail, however.  I might add that when a timing light was used, the lines or timing marks didn't even come up in the same universe let alone be apart. Not sure how long that was the case.  So I had to set it by ear.  The engine repotedly had less than 30K miles on a total rebuild, not sure thats factual....I mean I wasn't there to see it done.    Next, the van sat 5 years.
    Just this month, I charged the battery and started it, and same problem now except it has more of a tendency to want to overheat. And it idles slightly rough. And after a few mines, stalls out, more often than not not to restart for awhile.   It ticked for a couple of minutes but that smoothed out and stopped.    I replaced the coil and thermostat, fuel filter, all fuel lines, took off the gas tank and cleaned it well.  My fuel pump has pressure as is supposed to have.   I wonder if by chance the egr valve or the one way smog line check valves could be to blame?   Im really stumped.   Any insight you may have would be treasured.   John
    Number of posts : 12246
    1979 dogge transvan messing up Empty Re: 1979 dogge transvan messing up
    Post by donivan65 Mon Mar 31, 2014 4:35 pm
    Well,,,,,,,this site is for the Earlys,,,,up to 1970,,,,,,and if it has a hood, it aint no good,,,,,,,HOWEVER,,,,,,,,we do have a section called EARLY  ENOUGH  down in the camper section,,,,,which,,,you will find this post  moved to on Wednesday,,,,,,,,(you are taking up valuable van parking space here),,,,,,,that  thing probably has a vacuum amplifier and timer  on it, so take off the EGR valve, make a different gasket for it out of a soda can or something to block off the 2 holes in the intake manifold then bolt the EGR back on and see if anything changes,,,,,,,Hope you are in a Smog Exempt county,  you don't want to be having to get Smog tests on it.........I have a 78 Chevy Transvan and will be taking a 6000 mile back East in it  in a few weeks.....
      Current date/time is Fri Nov 22, 2024 1:03 pm
