by busman78 Sat Mar 04, 2017 8:11 am
Trans mission and radiator use the same mounting locations. V8 and /6 engine isolators are not the same. I believe the left frame bracket is the one needing alteration, I had V8 brackets so did not use the old /6 ones.
You did not mention if your 360 is an early or magnum version? This only makes a difference that for a magnum a little mod is needed on the right engine mount bracket.
As for pulleys you can not beat Bouchillon Performance, they are new made from the original Mopar dies, no guessing, excellent quality.
I will post some pictures of brackets, isolators and mounts that I used, right now the picture loading feature is not working, will post again later today.
