+57
SteelyVan
Bear
AzDon
mattimuss
whalemstr
LiveWire64
richie61
ditdater
Rick's 66 Chevy Van
Marcosis
Tice84
vern01
66_Barracuda
deepott71
kookykrispy
Vantastic
drc
kaz
64chevy
NipRing
scarlin
JAX
66mnecotruck
SDEconoTruck
61 posters
    Dons day,,,,,,,
    Number of posts : 14778
    Dons day,,,,,,, - Page 8 Empty Re: Dons day,,,,,,,
    Post by vanny Sat Aug 23, 2014 3:45 pm
    Now that's one Nice Piece of Work, Gov'na! Hard to believe that's going to fit in that little PT Cruiser! I want to see it go like Steve McQueen in Bullitt!!!
    Number of posts : 1731
    Post by Admin Sat Aug 23, 2014 8:05 pm
    Don, you are an artist when it comes to motors and anything else if it has 4 wheels! Very Happy
    Number of posts : 12246
    Post by donivan65 Sat Aug 23, 2014 9:31 pm
    ,,,I mess with 2 wheelers also,,,,,,
    Dons day,,,,,,, - Page 8 3_cycl10
    Dons day,,,,,,, - Page 8 Cubs10
    Dons day,,,,,,, - Page 8 Cycle10
    Dons day,,,,,,, - Page 8 Cycle_10
    Dons day,,,,,,, - Page 8 Cycle_11
    Dons day,,,,,,, - Page 8 Cycle_12
    Post by Admin Sat Aug 23, 2014 9:54 pm
    do you think you can fix the gears on my bicycle? its a Schwinn 6 Speed Cruiser... my gear shifter handle casing cracked and I can't seem to get it into really low or really high gear anymore  Sad  I can get into every other gear but....  may seem trivial to you, but it's not to me  Embarassed
    no it doesn't have a motor.... Wink  but I love it all the same! Very Happy
    Post by donivan65 Sat Aug 23, 2014 10:44 pm
    I think you need 1st gear more than 6th gear when you ride back home from Walmart in Temecula......
    what is the gear set up on the bike,,,,,,do you have 1 or maybe 2 cables that slide the chain from gear to gear,,,,how many sprockets on the rear wheel,,,,,how many on the pedals,,,,1st gear is usually the biggest on the wheel,,,,smallest on the pedals,,,,6th gear is smallest on the wheel,,,,biggest on the pedals,,,,
    Dons day,,,,,,, - Page 8 Dscn5312
    Post by Admin Wed Aug 27, 2014 12:04 pm
    The sprocket set up looks like the one you have pictured.  One cable, one sprocket on the pedals, 6 on the rear tire.  The shifter is built into the handle.
    Dons day,,,,,,, - Page 8 08271410
    Dons day,,,,,,, - Page 8 08271411
    Post by donivan65 Wed Aug 27, 2014 12:57 pm
    there are limiter screws that might have little springs on them on that swing arm that moves the chain onto the different gears,,,,,,they are for stopping the chain from going past the end of the gears,,,,,,,tip the bike over and pedal it while shifting gears,,,,,,see if the swing arm hits the screw stops before the arm moves enough to move the chain onto the gear,,,,,turn the little screws to let the swing arm move more in and out so it catches the biggest 1st speed and then the smallest 6th speed,,,,,
    Post by Admin Wed Aug 27, 2014 8:46 pm
    so from what you are telling me, this is the way to "fine tune" the derailer?  Am I right?  I have a "stationary training stand" to mount the bike to and "pedal" that may work better than just laying the bike on it's side...  if so...  another question...
    what do you recommend to lubricate the derailer? 3-in-1 oil or a good squirt if silicone spray?  or "clean it off" with the silicone spray and then "oil it"?
    Post by donivan65 Wed Aug 27, 2014 9:28 pm
    Anything is good to keep things rolling smooth,,,,,,even WD40,,,,,,the derailler moves the chain to each gear on the rear wheel,,,,,BUT,,,,,,,if you don't get all 6 gears,,,,the cable might not be moving it from stop to stop,,,,maybe those limit screws are stopping it from moving to each gear,,,,,maybe the selector is not moving the cable enough or not enough,,,,,so if you had to choose, which gear can you live without,,,,1st or 6th? put it on the stand,,,,,see how the selector moves that cable like if it does not pull the derailler far enough to get the chain to 1st gear or if hangs up and wont let the chain drop down to 6th gear,,,,,,normally you can adjust the cable to get at least 5 gears,,,,,1-5 or 2-6 when things wear out....push or pull on the derailler to see if it will grab another grille while you pedal it,,,,,,you might see where the problem is and then we can fix it.....
    Post by donivan65 Mon Sep 01, 2014 12:09 am
    ,,,,,,no crying in this video,,,,,,,,,
    Dons day,,,,,,, - Page 8 Th_cry_zpsb8e1951d
    Post by donivan65 Mon Sep 01, 2014 7:31 pm
    Me, Steve, Rich, Meyer and Chris got together today,,,,,,then Meyer, Steve, Rich and me cruised around and got some Chili Dogs,,,,,,
    Dons day,,,,,,, - Page 8 Dscn5329
    Dons day,,,,,,, - Page 8 Dscn5330
    Dons day,,,,,,, - Page 8 Dscn5331
    Dons day,,,,,,, - Page 8 Dscn5332
    Post by vanny Tue Sep 02, 2014 7:15 am
    Nice line-up!!!
    drc
    Number of posts : 299
    Registration date : 2010-09-13
    Post by drc Tue Sep 02, 2014 9:36 pm
    That does look like fun! Wish I could have been there...
    Post by donivan65 Tue Sep 02, 2014 10:04 pm
    now if you put down where in the 1000 miles of California you are, you might get invited to someones cruise,,,,,
    Post by donivan65 Sun Sep 07, 2014 7:50 pm
    Its time for the Main Event,,,,,,,,,,,the rear main seal,,,,
    Dons day,,,,,,, - Page 8 Dscn5410
    Dons day,,,,,,, - Page 8 Dscn5412
    Dons day,,,,,,, - Page 8 Dscn5413
    Dons day,,,,,,, - Page 8 Dscn5414
    Dons day,,,,,,, - Page 8 Dscn5415
    Number of posts : 1412
    Post by Vantasia Mon Sep 08, 2014 6:56 am
    I like that engine support trick from the inside! You the Main man....
    Post by donivan65 Sat Oct 18, 2014 10:27 pm
    My buddy Steve found out that his gas gauge quit working today,,,,,,,
    Dons day,,,,,,, - Page 8 Dscn5615
    Dons day,,,,,,, - Page 8 Dscn5616
    Post by vanny Sun Oct 19, 2014 5:17 am
    Nice save Don! At least he was able to get it off the road!
    64chevy
    64chevy
    Number of posts : 364
    Post by 64chevy Sun Oct 19, 2014 8:29 am
    Vanagain 2.0
    Post by Twinpilot001 Sun Oct 19, 2014 8:41 am
    Typical  FORD ECONOLINE!!!!!!!!!!!!!!!!!!!!!!!! affraid Evil or Very Mad lol! lol! lol! lol! lol!   RESCUED =By A =   CHEVY!!!!!!!!!!!!!!!!!!! cheers cheers cheers cheers
    You all =KNEW!! someone would do it!! cheers cheers lol! lol! lol!
    Post by donivan65 Sun Oct 19, 2014 9:54 am
    I keep having to dump out the  water  that I carry in that jug and put gas in it,,,,,,,,,,,,,,
    Dons day,,,,,,, - Page 8 Vanaga14
    Dons day,,,,,,, - Page 8 Vanaga15
    Post by vanny Sun Oct 19, 2014 10:51 am
    Hey Matt, seems the Chevy's run out of gas sometimes too!!!= Sorry, had to do it...Fair is fair! lol! Very Happy affraid
    Don, what is the charge for a road call? One chili dog or two? lol!
    Post by donivan65 Sun Oct 19, 2014 11:45 am
    I did get a Chocolate milk shake out of the deal after we got into town,,,,,,,but it just so happened that I was about 5 miles away at the time at Lowes, getting a load of concrete to finish putting a sidewalk around my motorhome  when he called me and said his van quit running,,,,,,he said the gas gauge shows he has gas and I had him pull the fuel line off the carb and tell me if gas squirts out when he cranks it,,,,,,,so no gas comes out,,,,,,,easiest test would be for me to bring him some gas and that got him back on the road,,,,,,but at Lowes, I surely like this $19 LED work light with a 12 volt and 110 cord,,,,,,it can light up a whole room.....
    Dons day,,,,,,, - Page 8 Dscn5619
    Dons day,,,,,,, - Page 8 Dscn5617
    Dons day,,,,,,, - Page 8 Dscn5618
    Dons day,,,,,,, - Page 8 Dscn5621
    Dons day,,,,,,, - Page 8 Dscn5620
    Post by vanny Sun Oct 19, 2014 12:55 pm
    Cool, I think I still have a $25 gift card from Lowes and now I know what I'll probably pick up next time I'm in that area. Thanks for the tip. Always nice to see what you're doing...especially underneath the van where all the scary creatures hang out when the lights are off!!! Or like in Omega Man (for those of you old enough to remember) when Charlton Heston would pull into his garage at night. Dons day,,,,,,, - Page 8 Omegam10
    Post by donivan65 Sun Oct 19, 2014 12:57 pm
    so thats where Jimmy Hendrix went,,,,,,,,,,,,,,,
      Current date/time is Mon Nov 18, 2024 8:25 am
