I got a set of replacement turn signals for my 65 for Christmas and started replacing them yesterday. When I removed the old ones I didn't like what I found!!!!!!! The originals have a foam type gasket behind them that apparently holds moisture between it and the body of the van. There was no visible rust around the lights just under the gasket. The one in the pic was the worst of the two. For now I just cleaned it up and put a good coat of primer on it.
The new ones didn't come with the gasket so I'm going to install them without one. Don't know if that gasket is even available. The new lights (from Brother's) are not near the quality of the originals.
