    Floor pan replacement
    gotdurt
    gotdurt
    Number of posts : 69
    Registration date : 2013-12-31
    Floor pan replacement Empty Floor pan replacement
    Post by gotdurt Fri Jan 10, 2014 2:37 pm
    I've tried searching the board on the topic, but surprisingly haven't turned up much... I'm looking at buying '64 that is in need of a passenger front floor pan... judging from the photos, it's a panel that is spot welded in place. Replacement pans for other vehicles are usually pretty easy to find online, but they seem to be missing for the 61-67 Econo's; I can find them for the Falcon cars and the gen 2 Econolines. Surely someone here has had to replace theirs?
    If not, then plan B would be to replace the panel with flat sheet metal; from what I can tell from photos, these pans are pretty flat, with very little, if any, forming. It looks like it would be a matter of drilling the spots, cutting a new pan to match the shape, and re-welding... Is there anything I need to consider that I may not be able to see from the photos?
    Floor pan replacement Empty Re: Floor pan replacement
    Post by Big W Fri Jan 10, 2014 7:57 pm
    Unfortunately the front floors panels are not being reproduced yet. That being said...someone in here posted that they were in contact with a company that could do it, but they would be a little high in price. I am not sure how far gone yours is but this is what it should resemble.Floor pan replacement 310
    gotdurt
    gotdurt
    Post by gotdurt Sat Jan 11, 2014 8:57 am
    On the top side it's covered by a sheet metal patch:
    Floor pan replacement Img_2410
    Here's what it looks like from underneath:
    Floor pan replacement Image11
    Floor pan replacement Image10
    It's the only rust on the van, save for a small spot in a fender. I'm not a talented welder, but I can get the job done. I could remove the existing pan and temporarily replace with flat sheet until I can find a proper replacement, but I would prefer not to do it twice...
    Number of posts : 326
    Post by jimthefred Sat Jan 11, 2014 2:51 pm
    My drivers floor sucks too! The only rust issue with mine also. May just use flat sheet and roll a few beads in it
    gotdurt
    gotdurt
    Post by gotdurt Sat Jan 11, 2014 8:17 pm
    FYI, I just found this thread:
    https://vintage-vans.forumotion.com/t37655-replacement-floorboards
    $50-75 is pricy, but worth getting it done right the first time.
    Post by Big W Sun Jan 12, 2014 8:14 am
    Yup those are the ones I was talking about. Thanks gotdurt for posting the link.
      Current date/time is Sun Nov 17, 2024 2:36 pm
