    12 Bolt Rear End ?? First Gen.
    65-G10-guy
    65-G10-guy
    Number of posts : 110
    Registration date : 2012-11-16
    12 Bolt Rear End ??  First Gen. Empty 12 Bolt Rear End ?? First Gen.
    Post by 65-G10-guy Sat Jan 04, 2014 1:17 am
    I am in the process of giving my 65 Panel a complete makeover. I plan to do some towing with it and I tend to load it up at times so would I be smart to upgrade to 12 bolt differential rather than rebuilding the 10 bolt?  Are they hard to find and will the 12 bolts from any other GM's be the same as the G10?  Thanks for the help, Jerry
    12 Bolt Rear End ??  First Gen. Empty Re: 12 Bolt Rear End ?? First Gen.
    Post by Twinpilot001 Sat Jan 04, 2014 3:37 am
    10 is all u really need-unless ur drag racing ??????????????
    Post by Digz Sat Jan 04, 2014 4:22 am
    The 1st gen 12 bolts came in 3:73s or 4:11s for ratios. While the center sections are different between the 10 and 12s. The size of the axles at the hub is the same. I am sure if you wanted to spend some money you could tame down those ratios in a 12 bolt but it sounds like it is much easier to play with ratios in a 10 bolt. I'm going with TP on this . The 10 bolt should be okay or no worse than a 12 bolt on load capacity. Now if you were going to adapt a real truck RA to the van you can gain in axle strength. But I know nothing about how that goes. Another thing , look at your GVW on the tag . There are recommended Max weights that your van is designed for. More weight equals more load on the stock braking and spring package.
    Number of posts : 12248
    Post by donivan65 Sat Jan 04, 2014 8:15 pm
    The 12 bolts are easier on the drivetrain if you are going up hills and stop and go traffic,,,,,,,but you give up MPG and top end speed,,,,,now Leftcoast65 surely wants to get rid of his 4:11 in his 65 Chevy Van,,,,,,
    65-G10-guy
    65-G10-guy
    Post by 65-G10-guy Sun Jan 05, 2014 12:55 am
    My current diff is 10 bolt open and I plan on going to a 3:55 or 3:73 posi.  That plus the tires I want put me in the cruising RPM range I want to be in.  Are the 12 bolts difficult to find or will I save a lot of time and money by re-doing my existing unit.  I suppose finding someone with a spare 3:73 posi 12 bolt is just a pipe dream.  Thank you guys for all the guidance. Much appreciated, Jerry
    Post by donivan65 Sun Jan 05, 2014 9:56 am
    ,,,,,,VanAgain has a 3:73 in his van,,,,,,,,,,those will have 11-41 stamped on the ring gear,,,,,,,I see them around,,,,,,,,
    Post by donivan65 Sun Jan 05, 2014 2:56 pm
    Well,,,,,,,6 years ago I cut up CrashVan and left the rear end at Vanishes place,,,,it was a 12 bolt,,,,,,PM him and see if he still has it,,,,,,,,
    12 Bolt Rear End ??  First Gen. Chevy_23
    Number of posts : 1048
    Post by VANagain Sun Jan 05, 2014 10:36 pm
    Hey Jerry,
    I've been wondering if I should swap out my 3.73 (12-bolt) for a 3.36.  I switched my tranny to a 700R4, which gives me lower first and second gears, so I don't really need the low-end help so much. I'll think it over.
    Plus, I'll tell Leftcoast65 about this. One of us would be up for a swap with you.
    65-G10-guy
    65-G10-guy
    Post by 65-G10-guy Mon Jan 06, 2014 12:33 am
    I am not sure what my ratio is, the van came with a powerglide.  I will see if I can figure out the ratio this week.  Vanagain, with that trans combo any idea what kind of RPM you are running on the freeway?  Thanks Jerry
    Post by donivan65 Mon Jan 06, 2014 9:54 am
    ,,,,if it is 10 bolts, it is a 3:36,,,,,(says 11-37 on the ring gear),,,,now all those rear ends came in PosiTraction versions also,,,,,so you will find 6 different types of rear ends in a 1st gen.........
    65-G10-guy
    65-G10-guy
    Post by 65-G10-guy Wed Jan 15, 2014 11:00 pm
    Well, the spin & count method confirms Donivans statement that it would be a 3.36. It is an open diff. If anyone in the area is willing to trade give me a PM and we will see if we can work out logistics.  Thanks  Jerry
      Current date/time is Sun Nov 24, 2024 10:44 pm
