ncbkr2002
    69 G10 350 swap
    ncbkr2002
    ncbkr2002
    Number of posts : 140
    69 G10 350 swap Empty 69 G10 350 swap
    Post by ncbkr2002 Mon Dec 23, 2013 6:03 pm
    Hey guys here are a few pix of my 350 /700R4 swap into my 69 .... hope you enjoy and more pix to come shortly .....
    ncbkr2002
    ncbkr2002
    69 G10 350 swap Empty Re: 69 G10 350 swap
    Post by ncbkr2002 Mon Dec 23, 2013 6:04 pm
    where did my pix go ???? ugh
    ncbkr2002
    ncbkr2002
    Post by ncbkr2002 Mon Dec 23, 2013 6:17 pm
    Code:
    69 G10 350 swap Phone_20
    ncbkr2002
    ncbkr2002
    Post by ncbkr2002 Mon Dec 23, 2013 6:18 pm
    Code:
    69 G10 350 swap Phone_21
    ncbkr2002
    ncbkr2002
    Post by ncbkr2002 Mon Dec 23, 2013 6:19 pm
    69 G10 350 swap Phone_22
    ncbkr2002
    ncbkr2002
    Post by ncbkr2002 Mon Dec 23, 2013 6:20 pm
    69 G10 350 swap Phone_23
    ncbkr2002
    ncbkr2002
    Post by ncbkr2002 Mon Dec 23, 2013 6:21 pm
    69 G10 350 swap Phone_24
    ncbkr2002
    ncbkr2002
    Post by ncbkr2002 Mon Dec 23, 2013 6:22 pm
    69 G10 350 swap Phone_25
    ncbkr2002
    ncbkr2002
    Post by ncbkr2002 Mon Dec 23, 2013 6:23 pm
    69 G10 350 swap Phone_26
    ncbkr2002
    ncbkr2002
    Post by ncbkr2002 Mon Dec 23, 2013 6:25 pm
    69 G10 350 swap Phone_27
    ncbkr2002
    ncbkr2002
    Post by ncbkr2002 Mon Dec 23, 2013 6:26 pm
    69 G10 350 swap Phone_28
    ncbkr2002
    ncbkr2002
    Post by ncbkr2002 Mon Dec 23, 2013 6:30 pm
    69 G10 350 swap Phone_29
    here is the poor ol 230
    ncbkr2002
    ncbkr2002
    Post by ncbkr2002 Mon Dec 23, 2013 6:32 pm
    69 G10 350 swap Phone_30
    now thats what i call .... room to work ... lol
    ncbkr2002
    ncbkr2002
    Post by ncbkr2002 Mon Dec 23, 2013 6:34 pm
    69 G10 350 swap Phone_31
    both of these were in running condition when i pulled them out the other day AND both are for sale if anyone is interested
    Post by G-Man Mon Dec 23, 2013 8:33 pm
    Looks great
    Post by Joe Van Tue Dec 24, 2013 2:22 am
    LOOKING GOOD the Van should move along nicely with that motor.!!!.You guys sure have alot of room for a V8 swap in those 2nd Gen's.. Smile
    Number of posts : 14778
    Post by vanny Tue Dec 24, 2013 5:17 am
    Nice work! More Power to Ya, and the Van!!!
    ncbkr2002
    ncbkr2002
    Post by ncbkr2002 Tue Dec 24, 2013 5:44 am
    thanks guys .... once i put the dog box back on im going to do some custom metal work on making a tunnel for air flow to cool the engine compartment and radiator ... ill definitly post pix as i go. on the build i dropped the engine 2 inches and will be making a custom tranny crossmember today with pix ... of course. the drive shaft i have from my Firebird will nedd to be cut down to 42 5/8 inches. i still need to figure out my radiator size and location and i am putting in a brand new 24 circuit wiring harness. hoping to have her on the road again soon. stay tuned ........... oh and MerryChristmas !!
    Post by Digz Tue Dec 24, 2013 5:55 am
    I see you had the level on the carb plate. make sure your pinion angles work out ok with your tranny hanger. The angle should be close to the same but it can vary a degree or 2. I'm thinking the carb plate comes in around 4-5 degrees off the drive line angle while the pinion is around 3*. Memory is a bit foggy there but something to look for.
    ncbkr2002
    ncbkr2002
    Post by ncbkr2002 Tue Dec 24, 2013 6:02 am
    thanks for that info Digz
    ncbkr2002
    ncbkr2002
    Post by ncbkr2002 Sun Jan 19, 2014 4:33 pm
    https://vintage-vans.forumotion.com/t38481-engine-cross-member-question ..... much more detailed pix at this link ... thanks for lookin and any comments
    kookykrispy
    kookykrispy
    Number of posts : 1533
    Post by kookykrispy Tue Feb 04, 2014 6:01 am
    Awesome! Looks like you built a hot rod SBC. Whats the details? Pistons? Cam? Heads? Intake, carb etc… Looks great. I hope it runs as well as it looks
    ncbkr2002
    ncbkr2002
    Post by ncbkr2002 Thu Feb 06, 2014 4:56 pm
    thanks kookykrispy .... its a 30 over 350 with big ol domed TRW forged pistons im pushing 10.5 compression ratio ... heads are 882 with all new parts ... 2.02 intake and 1.6 exhaust .... ZZ4 valve springs with full aluminum roller rockers that are 1.6 ratio true double rolle timing set ... the cam is a Voo Doo Bare Bones ... with the 1.6 rockers it now sports a 496 / 520 lift 224/234 duration @ .050 lift ... air gap intake and a new holley 750 vac secondaries MSD 6A ignition aluminum water pump and a 130 amp one wire altenator .... all bolted up to a 700R4 with a 2500 stall convertor and over $1200 in hardened and upgraded parts and a shift kit .... gonna be posting new updated pics hopefully this weekend !!! i am hoping to have it back on the road by the end of Feb !!
      Current date/time is Sun Nov 17, 2024 12:38 pm
