by donivan65 Sun Oct 20, 2013 11:32 pm
That old regulator uses up a lot of space,,,,,you can get rid of it and all the wiring on it,,,,,,F and 2 just go to the F and R terminals on the old Alternator,,,,# 3 goes to the horn relay,,,,,,and you cut #4 and run it to the new alternator,,,,,you can get rid of all that if you want,,,,,I would run a new 10 gauge wire from the output up to the Horn Relay as well as another from the Horn Relay to the Battery Cable on the starter solenoid with a 14 gauge fusible link to keep the van from burning up when the old wiring shorts out someday......
