by Old Skool Mon Aug 26, 2013 12:38 pm
Thats really kool and actually a little envious of taking off like you are doing,, That is great!!!!
If the picture of yours is the Blue Falcon,, you are will need to remember you are carrying more weight around every day, even before you load it up with kids and groceries.. and that IF the motor is a 144 it is working harder to get you down the road. Usually, the gearin is made high on purpose to make up for the lessor horse power. Gearing and horse power always work together.
15 MPG is really not bad for what you have and are carrying. It would be pretty hard to improve on that with the weight you are pulling and the motor. If you had say a 200 in there with a nice breathing set of headers and a better carb, then we could work on the gearing to match it and perhaps bump it up to 18 to 20, again,, yours a heavier basic weight compared to a regular van or pick up with nothing in them.
Which rear end do you have?? The 64 did come in an H/D version that had a nine inch in them, if so, gear changes are very easy.
Need to know which gears you have regardless of which type rear end,,,
Vic
