+6
iambeninla
RichardP
10 posters
    Blue Oval Conversion
    RichardP
    RichardP
    Number of posts : 77
    Registration date : 2013-08-10
    Blue Oval Conversion Empty Blue Oval Conversion
    Post by RichardP Sat Aug 10, 2013 9:22 am
    Hi Gang,
    Just bought a 65 Econoline pick up with a Blue Oval Six with Aussie Cross Flow Head.
    Currie 9" Granada Disk in Front. Its great. I would like to get some info on the engine size appears to be a 240 ci
    Anybody have a number where I can contact Sean. Blue Oval Tag and engine number are on the door.
    Thank you,
    Richard
    Blue Oval Conversion Empty Re: Blue Oval Conversion
    Post by G-Man Sat Aug 10, 2013 9:39 am
    Welcome to VV!!!!
    Number of posts : 2016
    Post by Barnabas Sat Aug 10, 2013 1:00 pm
    Post some pictures. Some of us can tell the engine by looking at it.
    If you can find the casting number on the block, here is a page to help you decode it.
    http://www.fordsix.com/castings.php
    RichardP
    RichardP
    Post by RichardP Sat Aug 10, 2013 6:12 pm
    Found this number on the engine block left side: B6DA6015AA
    Number of posts : 326
    Post by jimthefred Sat Aug 10, 2013 6:27 pm
    Im sure they are 250 c.i, Nice score!
    Post by Big W Sat Aug 10, 2013 9:30 pm
    Welcome to VV. Post a pic of your ride when you get a chance. Would like to see what you're working on.
    iambeninla
    iambeninla
    Number of posts : 60
    Registration date : 2012-12-02
    Blue Oval Conversion Empty Econoline pickup
    Post by iambeninla Sat Aug 10, 2013 9:59 pm
    Did you buy the red Spring Special that was on Ebay and Craigslist? I saw it at Long Beach swap meet last weekend.
    RichardP
    RichardP
    Post by RichardP Sun Aug 11, 2013 7:18 am
    Yes its the red one/Spring Special. I thought it was pretty good find and surprised nobody else jumped on it. Very much like the drive train installation by Blue Oval Engineering. Some of the wiring is kinda cluegy but its so easy to work on. Carb needs a little help, maybe a new one. Very happy with this, perfect for my retirement project.
    Post by Barnabas Sun Aug 11, 2013 2:53 pm
    RichardP wrote:Found this number on the engine block left side:  B6DA6015AA
    B6 would be 1956. Are you sure the first digit is a B?
    RichardP
    RichardP
    Post by RichardP Sun Aug 11, 2013 5:45 pm
    Could be an 8, and I have an old six sitting out back from 55 ford and they are very different.
    Also not sure I am looking at the right place
    RichardP
    RichardP
    Post by RichardP Sun Aug 11, 2013 5:48 pm
    Not looking at the right place for the number also maybe I should wire brush the numbers and dobble a little white paint on them, although it is pretty clean under there.
    Wish I could get a number for Blue Oval as the door sticker has his engine number on it. 1004
    Number of posts : 12246
    Post by donivan65 Sun Aug 11, 2013 10:29 pm
    Sean is at (626) 625-4745 econowest@hotmail.com
    LongBeachCA66
    LongBeachCA66
    Number of posts : 54
    Registration date : 2013-06-24
    Post by LongBeachCA66 Mon Aug 12, 2013 8:54 am
    RichardP wrote:Yes its the red one/Spring Special. I thought it was pretty good find and surprised nobody else jumped on it. Very much like the drive train installation by Blue Oval Engineering.  Some of the wiring is kinda cluegy but its so easy to work on. Carb needs a little help, maybe a new one. Very happy with this, perfect for my retirement project.
    Not knocking the quality of the truck, as it looked to be in good condition with some good equipment, but that truck is not a 65 and it is not a spring special.
    someone has mistakenly titled the truck as a 65 (easy to do as vehicles fall out of CA dmv system in 7 years if not registered. This one obviously fell out, and when the new owner went to register it they claimed it was a 65 and the DMV does not check) as the vin number on it clearly revealed it was a 61. There were other clues too, the 61-64 style heater, no 65-67 heater controls on dash. Also spring specials were all 5 windows.
    RichardP
    RichardP
    Post by RichardP Mon Aug 12, 2013 11:23 am
    Yes I know all these things and have no problem with it. The owner was very up front with it all.
    Thanks:sunny:
    RichardP
    RichardP
    Post by RichardP Mon Aug 12, 2013 11:36 am
    I do believe my Econoline pick up is a 1961 which should be a very early edition. Yes the seller was very upfront about that. Maybe the first year Econoline.
    Thanks,
    Richard
    Old Skool
    Number of posts : 1306
    Post by Old Skool Mon Aug 12, 2013 8:25 pm
    Looked at it and have had nothing to say other than a nice job from what I can see. The steering column dash bracket gave it away from the very first look. Under neath would certainly tell more. More than likely I would bet with that mill it has also had the full cross member put in.
     I just sold my cross flow and the cylinder head is identical, and for sure that is a 200 or a 250, the 250 easier to put that head onto. It is FAMOUS for a real breather as in one side and out the other like it should be. The Aussies took ours and MADE IT RUN.... VERY NICE TRUCK,,,,
    vicBlue Oval Conversion Aussie10
    Blue Oval Conversion 000_0511
    Blue Oval Conversion 100_1710
    Blue Oval Conversion Aussie11
    Blue Oval Conversion 100_1810
    RichardP
    RichardP
    Post by RichardP Tue Aug 13, 2013 7:04 am
    Wow FI and all. Mine looks a lot like the one on the wooden blocks only using a two barrel Holly. Yes it has the full cross member mounting, a header like the last picture only ceramic coated..
    At the moment I am just cleaning it up tiding up the wiring then getting it registered.
    The dizzy is a tight fit under the intake manifold, need to get in there and assure myself everything is Jake and perhaps put a Petronix while I am there. Sure don't want to remove the intake for this and I do think I can get the cap off as it sits.
    I have both seats out, much easier to work on or in the dog house.
    Thanks for everything,
    Richard
    Bluelemon
    Bluelemon
    Number of posts : 139
    Registration date : 2008-07-10
    Post by Bluelemon Sat Aug 17, 2013 9:28 pm
    Eugene Phillips ( Original Blue Oval ) would put the 65 Deluxe 3 piece trim on a lot of His Econolines.
    RichardP
    RichardP
    Post by RichardP Sun Aug 18, 2013 11:44 am
    Thanks, that solves the mystery. He or Sean did an exceptional job
    Got it registered and am fooling around with tiding up the wiring here and there.
    Richard
      Current date/time is Fri Nov 22, 2024 6:10 pm
