    Custom Griffin Aluminum 2 core radiators
    Custom Griffin Aluminum 2 core radiators Empty Custom Griffin Aluminum 2 core radiators
    Post by Guest Thu Feb 05, 2009 11:10 am
    Howdy gang, Very Happy
    A newbie to the group, old to the hobby. I've posted this on old econos too
    but would like to get it in front of you guys for your opinions. The long
    and short of it.... I've been doing some legwork to get a group discount on
    custom made aluminum two row Griffin radiators specifically for our
    Econolines. They come in two flavors, 17 1/4 x 17 1/4 and 20 1/4 x 17 1/4.
    The first measurement is the core itself between the tanks. Our tanks are
    top and bottom. Top inlet 1 1/2 x 1 3/4 bottom. I doubt there'd be a
    problem with changing position of inlet/output depending upon your
    requirements.
    With a group buy we're at $317, this is if I could get interest for 6
    radiators. Maybe a better deal if we could commit to more? Vic from
    another group is looking into 4 core pricing if we supply our radiator
    tanks. Waiting to hear back You'd go through Griffin directly. I'm not
    getting any money or cut. I'd be buying one myself if it all works out and
    makes sense.
    We had some interesting input on 4 core copper vs. 2 core aluminum. My
    position is this. I'm no expert in thermodynamics. I've put two aluminum
    Griffin radiators in Mustangs, the first into a 65 with an approximate 400
    HP 351W motor. Clearance was tight with headers. No cooling issues, no
    shroud either. Some say copper, some say aluminum is better. I've never
    had a copper 4 core so I can't offer an opinion. I think it depends on
    who's selling them. The selling point for me was that the larger aluminum
    two cores cool better, allegedly. I don't know. I can only tell you I
    haven't had any issues in nearly 20 years. The NASCAR guys and dirt/circle
    track racers all run aluminum. Is it because they're lighter? That's a
    given. I know they run these things WFO the whole race and they seem to
    work. I think most new cars run aluminum? They're made in the USA, South
    Carolina. That may or may not matter to some. It does to me.
    If you have a stock small or large six there's no reason to change. I'm
    planning on a swap in one or more of my Econolines in the future depending
    upon the glutton for punishment I wish to be. It sounds like a stock 240
    radiator will have issues cooling a stock 300 or 302. I think one of these
    two engines is where I'll land. I'm not going all out on performance.
    I welcome your input.
    P.S. : I get a kick out of these emoticons. lol!
    Custom Griffin Aluminum 2 core radiators Empty Re: Custom Griffin Aluminum 2 core radiators
    Post by Guest Thu Feb 05, 2009 8:55 pm
    I used a griffin 2 core in Vanishing Breed. Be sure to get the larger diameter tubes. Mine were 1 1/4" diameter and cooled like a five core. Mine was built to Eugene Phillips' specs by Griffin and cost $650.00 . The aluminum radiators dissipate heat much better than the stock ones and with the large diameter tubing heat dissipation is greatly increased. One thing though about Griffin is it takes them 4-8 weeks to make a custom radiator.
    Post by Guest Fri Feb 06, 2009 8:09 pm
    Good point on 1/1/4 diameter. John Weddington was going to check with Griffin today on Eugene's specs.
    Custom Griffin Aluminum 2 core radiators Empty Radiator I'm gonna try
    Post by Guest Sat Feb 07, 2009 3:31 pm
    Cost: $220.00
    Hi this is an all aluminum radiator for a 1932 FORD IT HAS BEEN CHOPED 3 INCHES IT IS 23 TALL it is 2 rows of 1 inch tubes !
    It will cool 600 hp ! it is all welded with NO EPOXY !!!
    IT IS A FRAME MOUNT YOU MUST DRILL HOLES IN THE SIDE PANELS FOR THE MOUNTS THIS IS DESING FOR THE BIG BLOCK HIGH HORSE POWER
    IT IS 171/4 INCHS WIDE PLUS THE BRACKETS AND 23 TALL , 3 INCHES THICK ON THE TOP TANK AND 2 5/8 ON THE CORE. BILLET FILLER NECK THIS IS FOR STICK SHIFT AND HAS NO TRANS COOLER
    <a href="http://tinypic.com" target="_blank"><img src="https://2img.net/h/oi44.tinypic.com/2ljqp0w.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
    Post by Guest Sat Feb 07, 2009 6:07 pm
    I'd like to see it but link doesn' work? confused
    Custom Griffin Aluminum 2 core radiators Empty radiator
    Post by Guest Sun Feb 08, 2009 12:10 am
    Its on ebay at superiorradiator its for a 32 ford
    Post by Guest Sun Feb 08, 2009 12:13 am
    Its got a domed top on it but by my measurements it should fit nice under the doghouse roof. The tabs on it looks like it shoulds line right up with the radiators cowl holes.
    Post by Guest Sun Feb 08, 2009 10:40 pm
    Still can't find it. Do you have an item number?
    Custom Griffin Aluminum 2 core radiators Empty sorry took so long
    Post by Guest Sat Feb 14, 2009 5:21 am
    Item number: 280311938697
    Custom Griffin Aluminum 2 core radiators Empty heres the pic of superiors radiator for 200.00
    Post by Guest Sat Feb 14, 2009 5:28 am
    Finally figured out how to get a pic on here.
    Custom Griffin Aluminum 2 core radiators Rad112
    Last edited by whitehog69 on Sat Feb 14, 2009 5:30 am; edited 2 times in total (Reason for editing : picture)
    Post by Guest Sat Feb 14, 2009 5:32 am
    i emailed them on outlet sizes top is 1 1/2. bottom is 1 3/4
      Current date/time is Mon Nov 25, 2024 11:07 pm
