has anyone put a a small fan in the back of the dog house. to pull in colder air in, or push out the hot air after the engine is hut off ?
neondv8
dog house exhaust fan
Re: dog house exhaust fan
i found this is on the web https://i.servimg.com/u/f34/17/54/82/24/1109cc10.jpg
- Number of posts : 12248
thanks donivan,
i have seen your setup. i was thinking of more of an exhaust . i put some aluminum over my electric fan so i need to do it in the back. https://i.servimg.com/u/f34/17/54/82/24/photo_20.jpg
slowflapper- Number of posts : 957
I haven't done it yet but Ive thought about trying a marine "in line" bilge fan to vent the doghouse. Mount it under the back of the van and run metal dryer vent underneath and into the dog house. Id make sure it is "explosion proof" though, if the air/fuel gets right in there it could !KB on you.
RipVanArkie- Moderator
- Number of posts : 987
Bilge fans are explosion proof, they are made to do exactly what you are wanting.
Later,
Rip
2013 MidSouth Econoline Meet
1967 Econoline Pickup
1966 Econoline Supervan
So that's what Kind of fan it is.
Cool I'm going to get two 3" inline fan.
If it is 3" I can use the Spectra flex tube
m1dadio- Chevy Guru
- Number of posts : 1778
a fan out of a computer power supply is 12 volts and explosion proof there are millions of then out there for free.
M1D
M1D
m1dadio- Chevy Guru
M1D
M1D
When I was running the two speed Taurus fan in my v8 pick-up I hooked the low speed up to a timer like don did on his. Never had a start up problem after that. Mick
m1dadio- Chevy Guru
If you want to get fancy. Many cars, especial VW in the 90's had an air temp sensor bolted to a valve cover screw and placed near the intake manifold. Connected through a relay it would make the fan run after the engine had been shut down until the air temp around the manifold and injectors had dropped.
that would be easy to add to the van and place the sensor near the carb.
M1D
M1D
RipVanArkie wrote:Bilge fans are explosion proof, they are made to do exactly what you are wanting.
This is true but Ive seen complaints (on Amazon) on some of the cheaper ones of "visible sparks" around the motor when its running so Id make sure I got a solid brand name.
66mnecotruck- Number of posts : 327
Registration date : 2014-02-15
Did you find anything Neondv8
in fact i did. i got a 3" inline fan from the local boat supply house. installed it in the dog house(as an exhaust fan to pull out air) ran spectra flex tubing down and out the DH. put it on a dial timer with a 5amp fuse. turned it on to test it ran good. drove for 30min parked for 20min. i didn't have a fuse to put in it so i didn't turn it on. got in the van opened the DH to put the fuse in and guess what. the plastic housing had malted. so i got another fan. this time t put in under the van and ran 3'' aluminum tubing in to the DH. worked ok, but i wasn't impressed. so i flipped the fan to blow air in. it worked much better. still in beta testing hahaha. ill take pic's this week and post them.
BTW the fan is loud as F#$K....i'm going to make an aluminum enclosure to put the fan in.
m1dadio- Chevy Guru
all those fans you throw away in old computer cases are 12 volt v fans. they can be put into a 3" hose
http://www.ebay.com/itm/DetMar-Marine-12-Volt-Tunnel-4-Blower-Boat-7-5-1C-/400632998524?_trksid=p2054897.l4275
This thing moves about 250 cfm. My "plan" is to put this inline with an air ram placed under the truck. I'm going to run one 4'' hose to the top of the doghouse and two 4" tubes out the back and use marine thru vents. That thing is a high pressure pocket, the cold air just skips below it.
