Does anyone offer a gas tank for a 1966 A100, or is there a close match that anyone has used.
1966 A100 Gas Tank
sbaines- Number of posts : 4
Registration date : 2013-04-30
1966 A100 Gas Tank
Re: 1966 A100 Gas Tank
Have you check with one of those shops that repair them. They can fix even a pretty bad one
- Number of posts : 8731
G-man is correct. we have not found any replacments and a good one it a rare find.
Yup, you can get an aftermarket fuel cell type or fix yours. Reproduction senders are available online as well.
I found a new sending unit on eBay and am having the tank relined. Thanks for the help.
1040imp- Number of posts : 42
Registration date : 2012-09-24
Probably nut much use to you, but I fitted a tank from a Reliant Scimitar ( a 60's/70's UK sportscar ).
It fits perfectly between the chassis rails and the A100 sender fits if you file a wee bit off the circumference of the base.
I had to relocate the filler neck but that was easy enough after the tank had been cleaned.
Cheers,
Hugh
Cheers,
Hugh
