+4
8 posters
    Cant wait for my new......
    Cant wait for my new...... Empty Cant wait for my new......
    Post by Guest Wed Apr 17, 2013 4:15 pm
    I cant wait for my new welder. I have only welded one time. it was about 15 years ago and i went blind for three days afterwards but i am ready to give it a more educated attempt. I ordered a factory refurbished Lincoln 125 mig welder
    i am gonna start slow with some floor patches then move to some exterior panels. should be fun. cheers
    Number of posts : 252
    Registration date : 2013-02-02
    Cant wait for my new...... Empty Re: Cant wait for my new......
    Post by campin'fool 2 Wed Apr 17, 2013 4:34 pm
    Thats a good easy to use welder. Get a self darkening mask, they make it a little easier too. Good luck and have fun!!
    Joel
    Post by Guest Wed Apr 17, 2013 4:46 pm
    Joel, oh i ordered one of those to Very Happy
    Post by Digz Wed Apr 17, 2013 5:19 pm
    Have a 125 in the shop, use it for all the sheetmetal stuff. Good machines.
    Number of posts : 890
    Post by jrinaman Wed Apr 17, 2013 6:10 pm
    just be careful not to get the tip too close. it melts the wire to the tip and you have to pull all the wire threw and replace tip. took me a while to get it right, always welded with a stick welder and couldnt adapt, almost had another to get refurbished. it did take a boot ride across shop a couple times.
    Number of posts : 322
    Post by Wheelie Wed Apr 17, 2013 6:56 pm
    I recommend to get some .025 wire and make sure your using gas for clean welds. Especially sheet metal. It really helps!
    Post by Digz Wed Apr 17, 2013 7:57 pm
    Wheelie wrote:I recommend to get some .025 wire and make sure your using gas for clean welds. Especially sheet metal. It really helps!
    Yep , What Wheelie says, it's a good way to go for sheet metal.
    Post by Guest Thu Apr 18, 2013 7:27 pm
    i didnt get a tank i was planning on using it with flux core. should i get a tank to learn?
    Post by Digz Thu Apr 18, 2013 7:45 pm
    the gas will make a lot nicer job of it. I also have a slightly larger one I keep stocked with flux core. I use that in a pinch and on thicker stuff where you can run more heat. You can use flux core, but you have to spend more time cleaning up the welds when you are done. If you might be chasing pin holes/thin spots or small gaps , the gas works best.
    Post by Wheelie Thu Apr 18, 2013 8:25 pm
    I agree, I would definitely get the gas. If you wanted just practice on scrap use the flux wire but any bodywork on the van should get the gas and solid core wire. You'll save time and money in the long run.
    Post by Big W Thu Apr 18, 2013 9:15 pm
    We also found that the flux core wire was a little harder on the lungs. The smoke it gives off while welding seems to be a lot more harsh, Even in a ventilated shop. I agree on using the bottle. My little lincoln mig loves it and so do my lungs...lol.
    Post by Guest Sat Apr 20, 2013 10:25 am
    thanks i will look into getting a bottle. i got the welder in the mail on thursday but i have not had time to even open the box. we have had flooding in our basement so i have been tied up with that.
    Number of posts : 3046
    Post by RodStRace Sat Apr 20, 2013 5:16 pm
    Gas for sure.
    Also, grab an old fender or hood and learn on it first.
    Gap, heat, speed and 'sizzle bacon'! THEN work on the van...
    Skulptor
    Skulptor
    Number of posts : 79
    Registration date : 2013-04-20
    Post by Skulptor Sun Apr 21, 2013 1:13 am
    All super good info.. and dont forget to jump around to different areas, as to not get too much heat into one area at a time. Even just a bunch of tacks welds at a time keeps the heat down that can cause warping.. I remember in my rookie welding years welding my first sheetmetal up and warping the heck out of a door, welding long continuous beads...
    Post by Wheelie Sun Apr 21, 2013 6:30 am
    I would suggest going here and reading information direct from Miller. Its good stuff.
    http://www.millerwelds.com/resources/improving-your-skills/mig/
    Post by Guest Mon Apr 22, 2013 4:44 pm
    thanks to everyone for fantastic info and resources. i tend to get into the reading aspect of learning and go overboard. My neighbor just stopped over tonight, I had completely forgotten he is a welder at a fabrication shop here in town. he has promised me tons of scrap to practice on and offered to help me learn hands on also. Awesome!!! as for gas i found 3 local sources. a friend told me that one of them has a "lease a bottle" program that lets you exchange as many bottles as you can go through the first year for less than the cost of purchasing a gas setup(unconfirmed)
    Number of posts : 14778
    Post by vanny Mon Apr 22, 2013 5:43 pm
    Congrats n8, nice to have helpful neighbors like that.
      Current date/time is Fri Nov 22, 2024 1:23 pm
