I had a buddy that's local to it go give it a test drive, he said he had a heck of a time trying to get it into gear. (three on the tree) It was probably partially due to the fact that he's a little out of practice with a standard transmission, but I'm betting that there's wear on the linkages that was making it a fight for him as well. (correct me if I'm likely wrong on that) He says there's a whine coming from either the rear end or the trans, but wasn't able to nail down exactly where it was from, which is honestly my biggest worry. The other concern I had was that the steering is supposedly sloppy, I don't know if that's just the steering setup itself or if something is worn out. He described it as having to go back and forth about two inches to keep the van going strait down the road. Overall the body is sound, there was some rust on the driver's side by the rear wheel well and a section below the driver's door. Both spots were patched in with fresh sheet metal. the paint is far from perfect where it was patched, but it's at least coated to keep it from rusting away again.
My plans for it are going to the local cruise nights, drive-ins, etc, and for towing my Wetbikes around in the summer. Maybe doing a few overnights in it, the back has benches built into each side that make a handy bed when you add a piece of plywood in between. So basically, is this worth looking at, or should I stay away? I'll be driving from MN with either a tow bar or a trailer to pick it up.
I can't yet post pics, so to see what it looks like, search for photobucket and exto
Thanks all!
