Murdock
66ThunderVan
2345.coupe
20 posters
my falcon econoline van
- Post n°126
Re: my falcon econoline van
Looking really good coupe! What are your plans for the floor?
2345.coupe- Number of posts : 92
Registration date : 2012-12-11
- Post n°127
patch the rot in the floor then por-15 the hell out of it..........millwright71 wrote:Looking really good coupe! What are your plans for the floor?
thanks vanny, it's coming good.......
- Post n°128
Dodger 359- Number of posts : 94
- Post n°129
Awesome work! Keep it up and it wont be long before another van is out on the road.
- Post n°130
thanks Dodger 359...........Dodger 359 wrote:Awesome work! Keep it up and it wont be long before another van is out on the road.
roughed the gas pedal opening in, used the leased amount of amps on my welder...next, sand it as smooth as possible then hit it again with the welder, this time increasing the amps and wire speed.Basically, I'm just making new, strong metal......
- Post n°131
Coupe, sounds like stepping back a bit helped you to think up what looks to be a good solution. Way to go, Amigo!
- Post n°132
thanks vanny.....to cut it out and fabricate the dips and curves would have been a challenge.It would have to be right on the money or the gas pedal would bind.I wasn't up to that much of a challenge. I took the easier, softer way....vanny wrote:Coupe, sounds like stepping back a bit helped you to think up what looks to be a good solution. Way to go, Amigo!
- Post n°133
got her all welded up.....turned out pretty good, nice and solid.....installed the gas pedal then ground down the bolt and welded it,that's the only way I could make sure the bolt would line up with the hole again.
Also found some more floor issues in front of the drivers seat. That's my next job, fixing more floor rot.......
- Post n°134
- Post n°135
Awesome work. Love the photos.
Big W- Number of posts : 3282
- Post n°136
Great gas pedal fix. I have the same problem with the floor as you did. Unfortunately most of us do because of water getting under the factory rubber mat. Will be doing same fix this summer. Great work so far...keep at it
- Post n°137
- Post n°138
- Post n°139
Getting there Coupe. Way to stick with it!!
- Post n°140
- Post n°141
- Post n°142
Ahhhhh, that's much better!
- Post n°143
- Post n°144
You are definitly getting there. Keep up the awesome work.
- Post n°145
COMMIN ALONG NICELY !!
- Post n°146
thanks you guys......
- Post n°147
Alright Coupe, hadn't seen anything from you in a while, nice to see you at it again. You are taking on a challenge a lot of guys wouldn't have. It's really beginning to show a LOT of progress. Is the epoxy primer to prevent future rust?
- Post n°148
Yes ,epoxy is to seal the metal so hopefully no more rust.
I've been obsessed on my '48 f-1 , got her on the road, working the bugs out. She's "fast and loud"
- Post n°149
That's great, wouldn't mind seeing a pic or two of that also. That's a nice pair of classics!!! There were a few "tease" shots of the f-1 through your windshield. I thought I remebered noticing it before so I went back through some of the earlier posts and saw them. She's a beauty!
- Post n°150
I'm worried that posting the f-1 pics would be inappropriate on a vintage van forum.....I will pm you or whoever want's to see my f-1 pics. Just let me know.I'll start with you vanny.
