if a 67 orig 6 cyl. clutch , has now a powerglide in it , but with orig radiator (no trans lines going into it ), and p/glide hooked to trans cooler mounted to middle ,pass. side of motor box , would it run hot ? looks wierd having no trans/lines to rad. and also area where trans cooler located ,like no breathing room, but i am no mech.
also it has shifter linkage ,shifting the p/glide patern upside down, would that be a hard fix to correct?
