    loose horn button
    Number of posts : 759
    loose horn button - Page 2 Empty Re: loose horn button
    Post by kiwimopar Sun Aug 19, 2012 4:07 am
    I take that back about needing a steering wheel puller Embarassed
    I always take my wheel off when working on the dash - as it only gets in the way...so I regularly take the wheel off Shocked Rolling Eyes
    I think a quality Philips driver and a flat blade are all that you need.
    Number of posts : 8769
    Post by dix Sun Aug 19, 2012 5:22 am
    now that i see it kiwi is right on the money. that center cap is very fragile mine looked simular and is made of glass i think. or at least broke like glass. try using some oil first around the edge
    Number of posts : 2036
    Post by dodge man Sun Aug 19, 2012 6:50 am
    you guys have been a big help, ispray it with penatrating oil first then treet it like glass, its probably never been off, i'll find out tomorrow, let u know how it went thanks again guys
    Post by dix Sun Aug 19, 2012 9:11 am
    take your time and you will do just fine....
    Post by kiwimopar Sun Aug 19, 2012 2:16 pm
    It's not glass - but just as fragile .... acrylic plastic or similar - fractures and splinters really easy Crying or Very sad
    Post by dodge man Mon Aug 20, 2012 3:14 pm
    thanks guys all it needed was tightened up, i put some lock tight on the threds, works great,
    Post by dix Mon Aug 20, 2012 3:22 pm
    wish every thing was that easy...
    Post by dodge man Mon Aug 20, 2012 3:27 pm
    thats for sure lol tomorrow i start removeing leafs i need to drop it 4'' i think 2 leafs from each spring will work,
    Post by dix Mon Aug 20, 2012 3:44 pm
    what size tires are you running.???
    Post by dodge man Mon Aug 20, 2012 4:12 pm
    195 14s front and 215 14 rear, i dont think i'll have any issues with rubbing,
    Post by dodge man Tue Sep 04, 2012 9:50 am
    i need the correct screws and washers or gromets to hold the horn button on, someone used the wrong screws thats what broke the horn switch, anyone know were i can get these screws and washers? if anyone has them i'll pay what ever you want, i'm into it now for 90.00 in a switch,
    Post by dodge man Tue Sep 04, 2012 11:53 am
    her isloose horn button - Page 2 T2ec1623 my horn ring
    Post by dodge man Tue Sep 04, 2012 7:20 pm
    i think i'll just give up on the stock steering wheel, and buy a after market wheel, that will fix my horn problem,lol whats a good size to use 17'' or 18'' and were do you get the installation kit, HELP!
      Current date/time is Sun Nov 17, 2024 4:34 pm
