Hey yall, just put a new clutch kit in on my 66 and I'm having some problems putting the transmission back in.
It keeps getting stuck where the trans mounts to the body. I can't slide it in enough to wedge it up into it's mounting bracket, so I was thinking that loosing the engine mounts and jacking up the engine from the front would tilt it back enough to let it slide in enough to slip into it's bracket.
Is this a sound plan, or is their something else I could try?
