by donivan65 Mon Jul 30, 2012 10:58 am
You could take those 3 bolts out and slide the torque converter back towards the transmission away from the flexplate and see if the noise changes,,,,,,you got to try everything simple before you get down to some serious money stuff,,,,,do a compression test,,,see if anything shows up out of the ordinary,,,,,I think we can drop the pan and see if any connecting rods are loose,,,,,but,,,,the odds are against you being able to fix the knock by changing some parts while laying under your van in your driveway,,,,,,take the valve cover off,,,,,bump the engine over a few times,,,,dont start it,,,put rags over the rockers,,,it will spray oil up,,,,,see if any of those rocker arms gets real loose after a few bump overs,,,,,
