Is there a secret or trick before I go braking stuff...I am talking about the horn button on the steering wheel....thanks Kevin
Best way to remove horn button
KEVINS750- Number of posts : 12
Registration date : 2012-05-22
scarlin- Number of posts : 258
Re: Best way to remove horn button
Push down and turn to the left Disconnect the battery if the horn works.
Sam
Sam
- Number of posts : 2011
scarlin wrote:Push down and turn to the left Disconnect the battery if the horn works.
Sam
Disconnect the battery first just to be safe.
Push in on the horn button and turn it a little to the left (counterclockwise for us old folks)
The spring inside should then pop the button out.
thanks guys. I need the blinker assembly out of my parts van for my daily...Kevin
Baczek- Number of posts : 48
Registration date : 2015-05-10
I was surprised to find there is a difference in springs between the Horn Button and the Horn Ring. I thought the springs were the same. Yours looks like the Button, which uses spring C1TZ 13A807-B.
Rear Counter has them listed.
http://www.rearcounter.com/C1TZ-13A807-B-parts310753.html
Spring - Horn Blowing Ring C1TZ 13A807-A
Spring - Horn Blowing Ring C1TF 13A807-A
Spring - Horn Blowing Button C1TZ 13A807-B (not for Falcon Deluxe Club Wagon)
