i guess the next major issues im having on my project is the current wheels under my van have too much dish and not allowing for enought clearance turn to turn without major rubbing. i need steelies in 14x5 or 6 that have alot of positive offset. little to no dish for lack of a better description. this will allow the wheels to get sucked in further allowing for the clearance i need. what vehicles can i look for in the junkyard that will make this happen?
KEVINS750
mothradeath
ok......i need to know what steelies are going to work in this situation?
mothradeath- Number of posts : 217
KEVINS750- Number of posts : 12
Registration date : 2012-05-22
I think some of the ranger steelies and maybe some aluminum may even be shallow enough for us....
Econoline64- Number of posts : 12
Registration date : 2011-03-07
You know the wheels on my old '87 Toyota P/U might work. They've got the right 5x4.5 bolt pattern and don't have much if any dish.
Scot in OKC
Scot in OKC
Hmmm. What model?
WOW!!!!! Are you going to run the 6 banger in that van???? With that ride height you might have to run 4 inch wheels with spacers and you may still have to flare the tubs. Do you have stops on that axle? If not you might need to fab something. BTW, that is one of the baddest custom frames I have ever seen!!!
Yea...there's quite a bit that has to go on to do this. Im trying to utilize the front stock axle but I did an axle flip and with the bodydrop its about a 9 inch drop altogether. I will fab the wheel tubs to accommodate the drop I will initially have when I do the mustang II front clip.
Hellfish- Number of posts : 146
Will the stock 14" wheels work? I have some I don't need.
im actually not sure at all. funny thing is ive had 3 of these now and none of them had stock steelies. the current one i just aquired actually has 4 different wheels. grr
score602- Number of posts : 140
Registration date : 2010-04-05
Diamond racing can make you what ever you want and powder coated almost any color for under 100 bucks a rim, just need measurements
