by SDEconoTruck Fri Jun 01, 2012 10:48 pm
Yes, the low starter will not accept your 3 speed transmission.
Here is an example of a low starter:
Notice the starter is BELOW the line of the Oil Pan and Block.
Most likely, your starters are both above the Oil Pan line. (High Starter)
Note: the 200 with a low starter is very rare. It is worth a lot
of money. It will not take the transmissions found in stock
Econolines. However, it has the bell housing bolt pattern of
the small block Ford V8. This means you can have a straight six
200 with a 5-speed overdrive transmission like the T-5, great
performance and great mileage. You can also use an AOD/AODE
overdrive automatic.
