+4
Smallblockbug
Hellfish
Linoman
8 posters
    How many Vanners to change a bulb?
    Linoman
    Linoman
    Number of posts : 329
    How many Vanners to change a bulb? Empty How many Vanners to change a bulb?
    Post by Linoman Tue Apr 10, 2012 4:15 am
    Does any one have a trick for easily replacing the front turn signal bulbs? My fat fingers can barely grip them. This seems like it should be such a simple task yet it sure frustrates me.
    Number of posts : 1747
    How many Vanners to change a bulb? Empty Re: How many Vanners to change a bulb?
    Post by econopoor Tue Apr 10, 2012 4:17 am
    You can use a short piece of heater hose to push the bulb in while turning it.
    Duane in Tennessee.
    Linoman
    Linoman
    Post by Linoman Tue Apr 10, 2012 4:23 am
    Simple solutions to simple tasks. Thanks. I'm up to 2 Vanners. Laughing
    Hellfish
    Number of posts : 146
    Post by Hellfish Tue Apr 10, 2012 7:39 am
    Or recruit someone with skinnier fingers. Smile
    Smallblockbug
    Smallblockbug
    Number of posts : 233
    Post by Smallblockbug Tue Apr 10, 2012 7:41 am
    Could always pop the whole light out and replace it while it is in both hands.
    Post by Twinpilot001 Tue Apr 10, 2012 8:20 am
    I always use either a bulb removal tool(made 4 that) or a long nose needle nose pliers-break bulb & get inside the area & push & twist it out.
    Post by Guest Wed May 16, 2012 7:59 am
    I reach behind and pull on the wires a little to relase the tension on the spring in the socket ... bulb falls out and is easy to put back in ...
    J=M
    Post by Twinpilot001 Wed May 16, 2012 8:17 am
    Heres what ive always done- needle nose pliers -long nose- break the bulb & insert the pliers inside the bulb area= pus in & turn to remove. If its rusted in - lube it & then also can squish/ crimp inside areas to get released.
    white-lightning
    white-lightning
    Number of posts : 237
    Post by white-lightning Wed May 16, 2012 12:40 pm
    Re-install them with some dielectric grease and they won't seize in place.
    Number of posts : 1868
    Post by HandiVanMan Wed May 16, 2012 1:08 pm
    Put some Krazy Glue on your fingers then stink them to the bulb. Wait for about 60 seconds then barely twist the bulb counter clockwise just a hair turn. Then pull the bulb out...... Walaaaaa there you go!!!
    Warning!!! Don't pick your nose or touch any private parts with the fingers with the Krazy Glue on them!!!
    Post by Guest Wed May 16, 2012 5:56 pm
    darnit ... I should have read that last part of the post about the crazy glue ... how I'm going to explain this in Emergency is beyong me ... rats ... lmfao!
    J=M lol!
    diamond dave
    diamond dave
    Number of posts : 565
    Post by diamond dave Sun Jun 03, 2012 12:06 pm
    i attach my van to my rotisserie. drain all fluids and remove anything from the inside that cant be secured.
    then i remove the lense, press a soft piece or rubber hose over the bulb. then i get a couple of buddies to rotate the truck aprox. 100 degrees on the rotisserie, and, shazaam!!!, the bulb comes right out.
    to install a new bulb, reverse the proceedure.
    Post by Guest Sun Jun 03, 2012 1:07 pm
    Get your wife to do it with her thin fingers.
      Current date/time is Mon Nov 25, 2024 8:19 am
