    Ok 1st Gen folks,what is ths?
    Ok 1st Gen folks,what is ths? - Page 2 Empty Re: Ok 1st Gen folks,what is ths?
    Post by Nightmoves Sun Apr 15, 2012 6:52 pm
    Lazarus,those were pretty common from days of old,in big trucks/semi's & dump's.While cars and pickups ran signals through steering columns,it was just easier/more economical to use these on bigger vehicles.
    They just stuck it to the left side of column and put a hose type of clamp on it.Some(cant tell for sure on yours)had a flat metal piece,that was turned down on end,under signal arm,you just pulled outward that worked as a 4-way.
    Some folks use these if signals are messed up in columns.Clip the wires,run to it(yours),clamp it.Then they have two signal arms.heh
    Number of posts : 1293
    Post by Lazarusvan Sun Apr 15, 2012 7:17 pm
    Nightmoves, makes sense. The former owner was an Esso oil truck hauler. My signals work, so might pass this along to someone who wants/needs it for a ratrod project.
    Number of posts : 12248
    Post by donivan65 Mon Apr 16, 2012 8:28 am
    I have that switch on my van,,,,,I bolted it right on the shift collar once I took the clamp off it,,,it does not cancel but I have 2 buzzers hooked to each turn signal bulb in the dash that lets me know if I left them on,,,,
    Ok 1st Gen folks,what is ths? - Page 2 Ts_swt10
      Current date/time is Mon Nov 25, 2024 7:33 pm
