Now that I've had the van on the road for a few weeks now I am fighting my carb adjustments. I knew before I got it on the road I would probably need to drop to a smaller CFM carb, from 600 to 500. But now that I'm digging around I think I should be running closer to a 350 CFM carb.
I can't seem to find any solid answers so I'm putting up here for a little help.
Online Carb. Calculators typically want the engine size, and Max RPMs.
I'm running a 250 bored .060, which as near as I can tell = 258 CID
I don't know the Max RPM for a 250, looking around the internet it looks like it varies, depending on how the engine was built.
Hopefully with the right carb. I can get better then 11 miles per gallon. I looked at a Holley 350 2BBL, but it says not to use it with an Automatic Transmission w/Overdrive. I don't know why it would make difference if the transmission doesn't require vacuum.
So, what are some of you running for carb size on your straight 6, and what is the basic setup of your engine?
