could anyone tell me the easiest way to tell a 170 from a 225 i have pics in my gallery thanks guys,dave
please help need a little info
kykayaker37- Number of posts : 139
Registration date : 2012-02-15
Re: please help need a little info
if i remember well its the lenght of the hose in the front of the engine, you should go to allpars to search for the exact lenght..my guest..corrosive
equium- Number of posts : 107
Registration date : 2011-04-25
Look for the small water line from the head to the block. If it's short (1 inch or so), it's a 170. If it's longer (2+ inches), it's a 225.
cool ill chek saturday thanks guys,dave
If you come back with the block casting number, you can get more info too. I have the info somewhere and can look it up if needed.
will do thanks man,dave somebody told me if the valve cover was ribbed its a 170 if smoothe 225 ill take pics of that hose to
Valve covers interchange, so that's not a good indication.
The bypass hose is the quick, sure way.
Check out slantsix.org for lots of great info.
Rod is right, i did change my cover for an ribbed old looking one, fits perfect(1966-1979), so not a good hint.
well i forgot to get the nmbr but that water pump hose is about a inch 2 clamps on it bout cover the hose that one would suck to change along side the road so i got a 170 cool got her rubnning this weekend after i rebuilt carb she purrrs thanks guys,dave
