I see where you are coming from. It looks to me like its about an even split on the 6 guys and the V8 guys, I dont have that dilema because I dont like 6 bangers, you can put as much money into a 6 as you can an 8 depending on what you have to do with it so I lean to the 8s. It's been to many years since I messed with a 1bbl carb to say much there, have you run a compression test on the 6 to make sure you aren't fighting something else? how many miles are on the 6?
The truck will probably not fit , we are geared for something in the 20" wide range in the 6 set up and I think 28" OA width on the 8s set up, most of the hooded stuff runs 32 to 34 " wide. You would probably have to do like Wideload said and get an aluminum rad that is as close as possible in dimension. some are refitting a mustang rad or something to work also. Once you get away from Stock , there is always fab of something it seems like.
