+6
Bear
10 posters
bears 1970 4x4 project
Vanish- Admin
- Number of posts : 5155
- Post n°26
Re: bears 1970 4x4 project
Bear .. Go with the 12 Bolt rear End !! Sell the 10 Bolt off !!!!!!
,,,Vanish,,,
MCMLXV
Bear- Number of posts : 849
- Post n°27
will do bill i can,t beleave i missed that i never looked till today.funny thing too is the 12 bolt is cleane no grease or grime both are going to clean up nice and fast.the 10 bolt ones are nasty grease balls.by this comming weekend i will have them cleaned up.
- Post n°28
rear axle
got my son working on cl[img]https://i.servimg.com/u/f42/16/02/85/79/14510.jpg[ni/img]eang up rear axle today
- Post n°29
https://i.servimg.com/u/f42/16/02/85/79/14010.jpg little amped there is he not ?
- Post n°30
- Post n°31
- Post n°32
got frount axle took apart today.this was one stock 1979 set up.url=https://servimg.com/view/16028579/70one bone s][/url]
- Post n°33
- Post n°34
Geeeeeeeeeez -too Bad-sad to see all That
- Post n°35
took cutting wheels, torches, hammer chicel and 2 days back in forth of just walk away bear.i had to cut the tub off the rotor on one side to get the hub nuts it was frozen on ther so good.your looking at the inside of the pig after duching it with parts wash it still has a way to go.
- Post n°36
Hey Bear, don't forget the axle tubes, I rigged up something like a cannon barrel swab to clean those out, It was unbelievable how much gunk and corrosion those had in them.
- Post n°37
yea digz it will be like cleaning a gun l.o.l
- Post n°38
A company I work for sells a product called metal rescue , won't hurt the metal, but will clean that rust in just a few hours
- Post n°39
where do i get some at chris ??
- Post n°40
- Post n°41
- Post n°42
- Post n°43
- Post n°44
- Post n°45
- Post n°46
Attaboy!
- Post n°47
Bear the place is in Howell, MI heres a link
http://www.metalrescue.com/home.aspx
- Post n°48
well if i did my home work right the gears in the 12 bolt set up are 308 not 3;73 ring gear is 40 teeth and pinon is 13 teeth.
- Post n°49
so it turns out i,m right both axles are 3;08 gear now since i got both tore down is 3;08 gear running a 700r4 trans going to run ok??
Stoopid john- Number of posts : 265
- Post n°50
You'll be able to set a land speed record in overdrive.
