    hinge seals?
    Number of posts : 3046
    hinge seals? Empty hinge seals?
    Post by RodStRace Thu Jan 26, 2012 10:55 am
    I'm looking at how to finish off the hinge area on my Dodge A-100.
    The factory just used filler to smooth the area.
    That would be fine, but I plan on using single stage inside and base/clear outside. My painter prefers to have a smooth transition and paint the base coat assembled, then disassemble and clear coat apart so there is not tape line on the jambs. This presents a problem since the hinges won't come apart if filled. I realize the jambs can be cut and buffed, but I'm exporing options.
    So I have been reading about the chevys and VWs having small rubber seals at this junction. I found the VW seals here.
    http://www.vw-wagenwerks.com/servlet/the-10238/HINGE-SEALS--dsh--Engine/Detail
    hinge seals? J10147
    I also found the Chevy suburban rear door seals at american classic.
    http://www.americanclassic.com/index.asp
    hinge seals? DRH-05
    Does anyone have these that could take measurements so I can see if they fit the dodge hinges?
    The Dodge hinges are 2.5" tall by .3" wide.
      Current date/time is Fri Nov 22, 2024 7:56 am
