+9
cl350rr
13 posters
    1964 G10 Panel in Alabama
    Number of posts : 823
    1964 G10 Panel in Alabama - Page 3 Empty Re: 1964 G10 Panel in Alabama
    Post by mbasaraba Thu Mar 08, 2012 5:36 am
    So last night my dad and I talked and I think I may change my plans of blasting the whole bottom of the van. We will use a hot water sprayer and get all the old junk off then touched up and reinforce the sealant already on the bottom.
    On a side note, the 235 that got pulled from the van was just sitting on my shop floor and I had never started it after I bought it. We decided that was a crying shame so we wired everything up on the floor and hook a set of boosters to my truck, poured a bitto gas in the carb and jumped the starter. 2 turns and it fired right up. Ran smooth as silk.
    I am thinking of looking for an older Chevy Truck to put the motor in or selling the motor. Runs great, has a new starter, alternator, points, cap, rotor, etc. Just hate to see it go to waste.
    Post by mbasaraba Sat Mar 10, 2012 4:28 am
    We found the stamp on the ring gear and it is a 2900 12 bolt rear with 4.11 gears. We are not sure how it is going to run with the 350 with auto tranny with OD so we are going to just use the rear end as is till we get it on the road then go from there.
    Regardless, I wanted to replace the bearings in the rear end. If this was for me to drive I would have just thrown it together, cleaned it and painted it, and put it back in the van. Since it is for the wife to haul 4 kids, I want everything new under this baby.
    Got the Axles pulled, and the ring gear assembly out. I had called O'Reily auto parts and they said they had the right bearings. I went in and got what they said went in the axles and the carrier bearings (these go on the ring gear assembly I guess?)
    Looking at my Shop Manual Supplimental (I take it this is like an add on manual or something?) it said to use tool # blah blah to install the bearing and oil seal into the end of the axle tube. Well we used a bearing puller and slide hammer and it ripped the guts out of the bearing that was in the axle tube and didnt budge the bearing sleeve itself. So we stuck a piece of tubing through the rear end and pounded it out from the other side. Something was definitely WRONG.
    The bearings I got from auto parts store looked like regular bearings and they didnt even have a number for the oil seal or the pinion inner and outer bearings. He showed me a "Repair Bearings" which was about an inch and a half wide and that is what it looks like was in my rear end. These bearings didnt side flush with the outside of the axle tube, stuck out like a quarter of an inch on both sides!
    1964 G10 Panel in Alabama - Page 3 Bearin11
    1964 G10 Panel in Alabama - Page 3 Bearin12
    Can anyone give me a break down of WHAT goes in the rear end? Part numbers from a parts store would be cherry since they dont have a phish to show parts and where they are going and such.
    Is the inside of the axle tube suppose to have a step? Wookee showed a picture of the bearing installed in his and it looks like the bearing was flush with the outside of the axle tube, is there a seal behind that. If this is the case, how does the bearing get lubed? Just with bearing grease??
    Seriously confused and I want to get this back together. Even if I have to order bearings online and get a full set for the rear end that is fine, I will return these I got and buy the full set.
    Post by mbasaraba Sat Mar 10, 2012 5:29 am
    Forgot to mention that the outer axle bearings they gave me are way to small to fit flush to the outside of the axle tube.
    Ok so took some more pictures.
    Here is the SLEEVE of the bearing assembly that I pulled. I just pushed it in to the first step in the tube just as reference.
    1964 G10 Panel in Alabama - Page 3 Bearin14
    Here is me holding the sleeve right outside the axle tube where I took it out.
    1964 G10 Panel in Alabama - Page 3 Bearin15
    The sleeve has the same step that is in the axle tube, however, it is too long to fit flush with the outside of the tube, it stuck out almost 1/4 on one side and a little less on the other.
    Suggestions? Is there a source for rear end bearings so I dont have to deal with a parts store that apparently isnt giving me the correct parts?
    Stoopid john
    Stoopid john
    Number of posts : 265
    Post by Stoopid john Sat Mar 10, 2012 5:42 am
    That bearing in the picture is to replace a bad bearing, that put a grove in the axle. If the axle has a step or grove in it you have to use that type of bearing or you need to buy/find a good axle. If the axle is good, you can use the stock type or the repair type bearing.
    I would want to use the stock type because the other is really a band aid. All it does is space a stock bearing to a good place on a bad axle. They use an o-ring because they sometimes don't seal very well.
    Stoopid john
    Stoopid john
    Post by Stoopid john Sat Mar 10, 2012 5:44 am
    They are going to stick out like that. Post a picture of your axles.
    Post by mbasaraba Sat Mar 10, 2012 5:55 am
    Yeah I gathered that since they called it the repair bearing. I appreciate the info, so I went out and looked at the axles.
    Here is the drivers side and it looks like it had pitting or chatter on the axle. I am not sure where THIS bearing was running and if that was the stock location or not?
    1964 G10 Panel in Alabama - Page 3 Two10
    Here is the passenger side. The shiny areas I took as the machined area where the bearing and oil seal were supposed to run but now not so sure.
    1964 G10 Panel in Alabama - Page 3 One10
    Stoopid john
    Stoopid john
    Post by Stoopid john Sat Mar 10, 2012 6:09 am
    The dull 3/4 - 1 inch section is where the stock bearing was and damaged them. The real thin line (in the second pic) is where the seal rides, the first pic shows that it would never seal because of the pitting. They both look kinda rough.
    Your only options are use both repair bearings or find new axles. The only nice thing about the repair bearing is that the bearing and seal are one.
    Post by mbasaraba Sat Mar 10, 2012 6:11 am
    I posted in looking for parts. Maybe best to just find a different rear end since the 4.11 gears are going to scream on highway speeds even if I am running an auto with overdrive.
    This project just keeps getting better.... **sigh**
    I appreciate the input! Thank you!
    Stoopid john
    Stoopid john
    Post by Stoopid john Sat Mar 10, 2012 6:50 am
    Rear ends are tough but when they go bad it gets $$ real fast.
    Post by Twinpilot001 Sat Mar 10, 2012 7:18 am
    get that overdrive tranny - it will be fine with that 4:11-1
    ratio - figure about a 27% reduction with overdrive trannys .Therefore @ 3500 rpm X 30%- around a 1000 rpm drop -2500-2800 rpm just figuring off top of my slow head .. affraid You may need all that 4-11 when ur loaded up with family & all the stuff!!
    Post by Big W Sat Mar 10, 2012 1:58 pm
    Just to add to that, get a lock up converter and that will help quite a bit also. 700R4 with lock up is what I will be putting in mine. According to my Trans expert who will be freshing it up said this will work great. Lock up on a switch or pressure switch will be the way to go. I want to keep my 4:11 rear as well.
    Post by Digz Sat Mar 10, 2012 2:13 pm
    Matt , the 4:11 is totaly streetable with the OD tranny, It might not be the best combo but its OK, I'm running the same thing also using the repair bearings. I see they did not remove the ridge where the axle and flange meet when they put those in, the seals were probably almost if not already toast anyway. There are several threads by Donivan and some input from others including myself on the installation of them. Better axles would be the best solution, but they are tough to find and I believe a bit pricey to have made but I don't think I have ever heard any hard numbers on that cost. Your entering the "been there done that " club.
    Post by Digz Sat Mar 10, 2012 2:53 pm
    This is what you need to do to get the repairs bearings on without destroying them.
    1964 G10 Panel in Alabama - Page 3 Ground11
    This side goes towards the housing, they are sealed supposedly and do not use the grease in the pig. I have not heard how long they last. I have 2 seasons on mine.
    1964 G10 Panel in Alabama - Page 3 Bearin10
    Side towards flange, the reason for knocking the ridge back is to allow you to push the axle in far enough to put the C-clip back in without wrecking the seal.
    1964 G10 Panel in Alabama - Page 3 Repair10
    And this is how they end up, sticking out a bit.
    I see you have some threads going on another rear end, it might be a good idea those axles look extra shabby to me but I'm no expert on what can be saved using the repair bearings. Mine were not good either and its doing ok, but thats all I can say on it ,,LOL
      Current date/time is Fri Nov 22, 2024 2:58 am
