+4
SDEconoTruck
8 posters
    Van Weight Front To Back
    Van Weight Front To Back Empty Van Weight Front To Back
    Post by Digz Mon Dec 12, 2011 1:44 pm
    I posted this in VCVC also , but it might give anyone with a short wheelbase van an idea of where they are at.
    Van Weight Front To Back Weigh_10
    Id call this a somewhat typical V8 auto trans swap with a full paneled interior on a 65 Chevy. If I remember right these have an estimated curb weight of 2800# basically equipped. What I got now:
    3640 Total
    2160 Front
    1460 Rear
    The 20# difference might be because the dog moved or the fact there was a small ramp to the ends of the scales which I tried to minimize by staying close. I really thought the rear bias might have been a little more.
    Number of posts : 7905
    Van Weight Front To Back Empty Re: Van Weight Front To Back
    Post by DanTheVanMan Mon Dec 12, 2011 2:10 pm
    Now that is some good info!!!! Especially since I'm in the middle of a brake conversion!!! Smile
    Dan
    Van Weight Front To Back Qr_cod10
    Number of posts : 12246
    Post by donivan65 Mon Dec 12, 2011 3:45 pm
    My van with a 6 cylinder and 3 speed weighs 4000 lbs with me in it,,,,,,
    Post by Digz Mon Dec 12, 2011 3:57 pm
    donivan65 wrote:My van with a 6 cylinder and 3 speed weighs 4000 lbs with me in it,,,,,,
    ...It must be all that glass and those extra parts and tools you carry....
    Post by donivan65 Mon Dec 12, 2011 4:15 pm
    YEP!
    SDEconoTruck
    SDEconoTruck
    Number of posts : 310
    Post by SDEconoTruck Mon Dec 12, 2011 8:27 pm
    My pick up is 2660 with almost a full tank...
    ...I bet the bias is even more on the front of mine.
    Number of posts : 822
    Registration date : 2010-09-10
    Post by Roman Mon Dec 12, 2011 8:43 pm
    My '64 panel wet with 4-speed and 350 V8 fully gutted interior weighs 3140.
    Number of posts : 890
    Post by jrinaman Mon Dec 12, 2011 8:45 pm
    mine was 3400 with 6 cylinder, turbo 350 and wood panal interior.
    Number of posts : 3046
    Post by RodStRace Tue Dec 13, 2011 7:29 am
    Great info, Thanks for posting!
    Guess I'm going to have to watch what I use for an interior.
    Post by Digz Tue Dec 13, 2011 12:58 pm
    It was the weight bias I was more curious about than anything. It seems to hook up better than I thought it would have and the brakes I must have gotten set real close (lucky) because they seem to set it down quite well without alot of nose dive. I don't think there is much I could do to change it either, seeing as most of the front weight must be from glass and the extra structure in the doors and such. Im sure the engine and trans adds to it but that is really most behind the front axle but close to it. See how the next one ends up ,,LOL
    Number of posts : 2632
    Post by savage Thu Dec 15, 2011 8:14 am
    Joe . you got any Idea what a 454 & PG might weight?? Kind of wondering how much diff from 230 6 & 3 on tree ,to the BB & PG. Think I need more leafs on front of the 65 DV
    Post by donivan65 Thu Dec 15, 2011 9:54 am
    My van has 6 leafs up front and 7 in the rear as well as air bags back there.....
    Post by Digz Thu Dec 15, 2011 1:45 pm
    Tom if my numbers are right/close you gained about 340#, and all but 5# of it in the engine. The BB comes in at 685# with stuff on it, the powerglide only 95# (by Wiki). The saginaw 3 speed is supposed to only weigh 90#. As far back as that engine is in the DV, probably only about 2/3 of that would be on the front.
    Don you put your van to the task more than alot of folks do with a PU !!
    Post by donivan65 Fri Dec 16, 2011 9:35 am
    And that brings up front wheel bearings,,,,,I sure go through a lot of them,,,,,all I find now is the ones made in Pakistan, Japan, Taiwan, Korea, China and Mexico,,,,,,even RockAuto says their bearings are made in Europe,,,,,sure would like to find some Set 2 and Set 6 bearings made in the USA.
      Current date/time is Fri Nov 22, 2024 5:44 pm
