+5
9 posters
    noise similar to bad shock
    Number of posts : 890
    noise similar to bad shock Empty noise similar to bad shock
    Post by jrinaman Wed Dec 07, 2011 10:20 am
    noticed a 'thunk' noise coming from drivers front wheel area. sounds like bad shock but they are new and there is no play with weight removed, plus ride is still good. i checked all around are and all is tight except some play in king pin. there was a little play there a couple monthes ago but has tripled since then. could this make the constant thunk noise as i hit bumps? is it safe? what else could make the noise?
    Number of posts : 12245
    noise similar to bad shock Empty Re: noise similar to bad shock
    Post by donivan65 Wed Dec 07, 2011 11:07 am
    Take that shock off and see if the noise goes away,,,,,,
    Number of posts : 575
    Post by austinmodhouse Wed Dec 07, 2011 12:07 pm
    do you have a sway bar? I’ve had that happen w/ bushing was gone.
    Number of posts : 1778
    Post by m1dadio Wed Dec 07, 2011 12:30 pm
    Check your brake parts too, anything loose could be clunking over bumps.
    M1D
    Number of posts : 8769
    Post by dix Wed Dec 07, 2011 1:36 pm
    look for a broken leave spring.
    Post by jrinaman Wed Dec 07, 2011 8:23 pm
    no sway bar, caliper is tight but didnt remove wheel to check ? did look at leafs, all looked good and plastic pads between leafs still there. will pull wheel and then remove shock. when i jump on it, it clunks just as front end lightens, when i let off, it clunks again as front end drops. had a buddy stand neer van while i did this and he confirmed drivers front wheel area.
    Post by donivan65 Wed Dec 07, 2011 8:32 pm
    After you pull that shock off and see if the noise goes away,,,,,start looking at the bushings in the springs and shackles,,,see if the bolt in the front perch is loose or the hole is enlarged,,,,
    Post by jrinaman Wed Dec 07, 2011 8:35 pm
    ya, thought of that but dont think the wiggle test will work on that. any ideas, other than removing 47 year old bolts?
    Post by Digz Wed Dec 07, 2011 8:38 pm
    Check your motor mounts also, pads and the bolts that hold the Xmember.
    Post by jrinaman Wed Dec 07, 2011 8:54 pm
    good point digz. i had cut and rewelded the mount at crossmember, side closest to wheel. i remember having trouble with it, couldnt clean properly, or couldnt reach at right angle. dont remember but i do remember i wasnt pleased with weld.
    Post by donivan65 Wed Dec 07, 2011 8:56 pm
    You cant see the cartridge in the front spring,,,,take a hydraulic jack put it on the top of the front spring and jack up the frame a little,,,watch the bushing see if it is loose as you let it down,,,,put a bar in there see if the bushing moves,,,,jack up the frame,,,take the pressure off the spring,,,,see if there is play in the bushings,,,,
    Post by jrinaman Wed Dec 07, 2011 9:05 pm
    thanks donavan. got a full day tommorrow and maybe friday so looks like a weekend job.
    Post by donivan65 Wed Dec 07, 2011 11:10 pm
    ,,,,maybe the shock is wrong and it's bottomimg out......
    Post by jrinaman Wed Dec 07, 2011 11:16 pm
    no, wouldnt explain clunk upon acceleration.
    Number of posts : 7905
    Post by DanTheVanMan Thu Dec 08, 2011 5:49 am
    Sounds like a Front Spring bushing. My Sportvan did the same thing when I first got it.
    noise similar to bad shock Qr_cod10
    Post by donivan65 Thu Dec 08, 2011 11:06 am
    noise similar to bad shock Nodoor31
    Post by Twinpilot001 Thu Dec 08, 2011 11:21 am
    OOPS!! Weld & Drill??
    Post by donivan65 Thu Dec 08, 2011 1:16 pm
    Yep
    noise similar to bad shock Nodoor32
    Post by jrinaman Thu Dec 08, 2011 5:24 pm
    well i found 2 things today. i used a head bolt on the bottom of shock. it is smaller diamater in the center and shock moved enough to make clunk. after replacing that, i used a pry bar to lift and drop spindle at king pin. it moved up and down slightly and made a similar sound. i greased them up and sound went away. no noise on the way home. i think the shock was making the noise but i need new kingpins either way.
    Post by donivan65 Thu Dec 08, 2011 7:12 pm
    noise similar to bad shock Repai164
    Post by jrinaman Thu Dec 08, 2011 7:44 pm
    so how hard was it to beat them out?
    Post by donivan65 Thu Dec 08, 2011 7:57 pm
    You take the steering knuckle off, then the 2 dust caps, remove the pin and it falls out on your toe,,,,,,and if that don't happen, it goes downhill from there,,,,try and tap the kingpin shaft down,,,,try to press it down with a clamp,,,,heat it up with a torch,,,,,but that shaft needs to come out for you to remove the spindle and then remove and replace the kingpin bushings,,,,,
    noise similar to bad shock Repai165
    Post by jrinaman Thu Dec 08, 2011 8:05 pm
    i have heard horror stories about removing the pins and bushings.
    Post by donivan65 Thu Dec 08, 2011 9:06 pm
    ,,,,,,and you don't know which is your story until you knock the lock pin out,,,,,,,but they usually come out,,,,,
    Post by donivan65 Thu Dec 08, 2011 9:53 pm
    ,,,,,aint none of them Kingpins got the best of me and my ball joint clamp and electric impact gun,,,,,
    noise similar to bad shock Repai166
      Current date/time is Sun Nov 17, 2024 6:53 pm
