    WHEEL CYLINDERS Part numbers and prices
    WHEEL CYLINDERS Part numbers and prices Empty WHEEL CYLINDERS Part numbers and prices
    Post by Guest Fri Nov 25, 2011 1:47 am
    Autozone has the best prices, Better then Macs Auto if you add in shipping charges. Some the Big Stores carry only the fronts and the kits for the backs. Most places wanted between $20-$35.00 each!
    Left-Ft________________________Right-Ft
    Autozone#-33220--($12.99_______Autozone# 33221 ($12.99)
    Bendix#---33220_______________Bendix# 33221
    Wagner#---WC-18290-------------------Wagner# WC-18291
    Dorman#---W-18290---------------------Dorman# W-18291
    Left-Rr---------------------------------Right-Rr
    Autozone#-33278 ($8.99 )-------Autozone# 33279 ($9.99)
    Wagner#---WC-37782-------------Wagner# WC-37783
    E-LINER
    NOTE. Autozone does not have a the listing for the rear wheel clyinders. Not under Econoline, Falcon, and yes sometime under 1966 Bronco's.
    I just cross reference it Sorry about the condensed columns. AFTER I GOT THE PARTS, I HAD TO GRIND SOME FLAT SPOTS ON ONE OF THE REAR CLYLINDERS. IT TOOK ME 20sec. TO GRIND IT DOWN TO FIT FLUSH. IT WAS HITTING THE BOSS AREAS OF THE BACKING PLATE
      Current date/time is Mon Oct 02, 2023 8:14 am
