It keeps getting better...
I'm now having some issues when shifting into drive and getting it to actually catch. It seems to be at cold starts and is fine later on.
Mechanic that's been helping me believes it could be that the tranny seals have dried up and that when the fluid finally warms up, it passes over the seals and does the job its suppossed to.
When it won't catch, I can give it gas and kind of force/jump it into gear, but that's not good, obviously. Any other things it could be? I mentioned it to another shop foreman that has muscle cars and he said that exact scenario with cold vs. hot start tranny going into gear sounds like a possible issue down the line as well.
Previous owner says it was rebuilt 6 years ago and has less than 1,000 miles on it and that he only drove it once a week to the grocery store.
I'm wondering if the seals dried up from lack of use/lube? My mechanic kinda of hedged at that thought and seemed to feel it was unlikely IF the tranny had been rebuilt.
After replacing valve gasket seals today that had been layed down over pieces of old gasket and causing a pretty good leak, anything is possible, including a shoddy tranny rebuild??
He also says that this shifts through it's gears rather quickly and doesn't really let it wind out like it should. It appears that the mechanism that can be adjusted for that (right side of carb, cable type of thing with a plastic piece) is all the way out, which leads him to believe the governor spring may be hung up or not functioning. Also due to lack of driving?
He feels that if I take off balls to the wall and don't let off the throttle that the gears shift too quickly and it could damage the tranny. Without knowing the state of the tranny, he is afraid to go wide open throttle. Does any of this make sense?
