+6
Eagle1
Wrong Way
10 posters
    Salvage Playgrond
    Wrong Way
    Wrong Way
    Number of posts : 32
    Registration date : 2011-08-13
    Salvage Playgrond Empty Salvage Playgrond
    Post by Wrong Way Sat Oct 29, 2011 5:48 am
    I was at the playground yesterday getting a turn signal lens for my truck (damn deer) and as I was walking by the crusher and saw the big fork lift picking up a 1969 window van getting ready to send it to its grave. I yelled at the guy, and after a short time of trying to translate, I got him to put it to the side. This van has a lot of parts. I spent the day stripping parts and will be going back Monday to try and get some of the bigger ones. What I have got so far> 4 pop out windows, original radio (works) and antenna (complete), dash cluster (great shape), front door glass with vent windows, rock guard, battery door and rack, radiator & shroud, turn signal lenses and a few other small parts. It has a small block 283? auto trans and a 12 bolt rear with 6 lug axle's (don't know if it is posi). The body is in bad shape.
    Does anyone need anything?
    Dennis
    Number of posts : 512
    Salvage Playgrond Empty Re: Salvage Playgrond
    Post by pan58head Sat Oct 29, 2011 5:50 pm
    Hey Dennis I would be interested in a pair of pop out windows. Also if there is a auto column somebody here is going to want that. Trans mount? another hot item Bob
    Last edited by pan58head on Sat Oct 29, 2011 5:51 pm; edited 1 time in total (Reason for editing : spelling)
    Wrong Way
    Wrong Way
    Post by Wrong Way Sun Oct 30, 2011 3:29 am
    Out of the four windows two are in great shape and I'm sure you know where they are going. The other two have a little rust around the bottom part of the frame but you are more than welcome to them.
    Would they want the steering column with the steering box? I will get it all if you think somebody would want it.
    The rear trans mount is gold! I have been doing some reading here about changing over to auto with a V8 and have read about the make shift trans mounts. I will be keeping this. I also want the engine bracket and mounts. Plus the twelve bolt rear.
    Dennis
    Eagle1
    Eagle1
    Number of posts : 144
    Registration date : 2010-09-18
    Post by Eagle1 Sun Oct 30, 2011 5:48 am
    Dennis,
    If the plastic defroster outlet vents that sit on the dash are good I need both.
    Thanks Eagle1
    Wrong Way
    Wrong Way
    Post by Wrong Way Sun Oct 30, 2011 6:25 am
    That was the first thing I took off. I needed both because mine were broken. Sorry.
    Dennis
    Number of posts : 1293
    Post by Lazarusvan Sun Oct 30, 2011 7:06 am
    Hi, Dennis. Great job on the "pet rescue" at the playground. I need this part right here. Not sure of the name, but it's on the passenger door. I'll take both sides if in good shape. I assume it's the same part for first and second gen since doors fit both vans. Thanks, Lee
    Salvage Playgrond Door_v10
    Wrong Way
    Wrong Way
    Post by Wrong Way Sun Oct 30, 2011 7:23 am
    Lee, I will look for them when I go back Monday. if they are good, I will grab them for you! Dennis
    Post by G-Man Sun Oct 30, 2011 8:41 am
    Laz are you sure thats a stock part??? Don't remember seeing anything like that on my 64
    Post by Lazarusvan Sun Oct 30, 2011 9:35 am
    G-Man wrote:Laz are you sure thats a stock part??? Don't remember seeing anything like that on my 64
    No clue. It's what came on here. Does your just have a hole?
    Number of posts : 7905
    Post by DanTheVanMan Sun Oct 30, 2011 12:07 pm
    Yep, Those are an "Add-on" for sure. But considering what those vents are for it's actually a very good idea!!
    Lee, If you want to replace them I would hit the JY and start checking out 1980's full size vans and trucks, bet you could find a set!! I'm heading out tomorrow and will check a few if I have time to see if I can figure out what they came from...
    Funny thing is those have "Directional fins" indicating these are a defrost vent cap...
    Dan
    Salvage Playgrond Qr_cod10
    Post by Digz Sun Oct 30, 2011 12:33 pm
    Looks like a heat vent from a house to me.
    Post by Lazarusvan Sun Oct 30, 2011 1:03 pm
    Digz wrote:Looks like a heat vent from a house to me.
    Digz, I doubt it. It's plastic and seems to small. Glad my "rat rod" mod could provide discussion Razz I can envision them being metal and chromed out.
    Since it's being discussed, is this normally just a hole?
    Post by G-Man Sun Oct 30, 2011 3:47 pm
    mines metal there no vent
    Post by Lazarusvan Sun Oct 30, 2011 4:17 pm
    G-Man wrote:mines metal there no vent
    Just an open hole or is there trim? We like photos...
    Number of posts : 1389
    Post by wideload Sun Oct 30, 2011 5:01 pm
    Stock doors don't have any opening there, just sheetmetal. Someone must have added those to your doors. Good idea to help keep the inside of the doors dry.
    Post by pan58head Sun Oct 30, 2011 5:24 pm
    wrong way you have mail Bob
    Post by Lazarusvan Sun Oct 30, 2011 5:29 pm
    Funny, I never questioned it since it was there when I got it. Never owned an early before...
    Wrong Way
    Wrong Way
    Post by Wrong Way Mon Oct 31, 2011 2:03 pm
    OK to settle the issue of the vent, They are not on the vans...the were, on the other hand, put in later models (trucks, vans, cars) (usually stamped metal vents) to ventilate the doors from moisture. Done...
    Dennis
    Wrong Way
    Wrong Way
    Post by Wrong Way Mon Oct 31, 2011 2:07 pm
    By the way, I was not trying to be rude! Just trying to let you know the history of the vented door.
    D
    Number of posts : 823
    Post by mbasaraba Tue Nov 01, 2011 4:15 am
    Lazarusvan wrote:Hi, Dennis. Great job on the "pet rescue" at the playground. I need this part right here. Not sure of the name, but it's on the passenger door. I'll take both sides if in good shape. I assume it's the same part for first and second gen since doors fit both vans. Thanks, Lee
    I could easily make you a nice polished Aluminum set. Wouldn't rust and they would have a mirror finish. I could even make the cut outs in the shape of the Chevy boetie if you wanted.
    Post by mbasaraba Tue Nov 01, 2011 5:11 am
    Something like this. The Bow Tie could be smaller with more of them or anything really. I have .025 and .063 thickness 6061 Aluminum. The polished finish is amazing.
    Salvage Playgrond Chevyv11
    I dont know why I cant get these pictures to center when I use Photobucket.
    Any help on that?
    ChevyVanMan1
    Number of posts : 425
    Post by ChevyVanMan1 Mon Nov 07, 2011 9:05 am
    Great idea for venting doors. There was a certain year and after that the had to have a one way flap to keep loose fuel from moving forward at impact. Don't think it would make any difference our our tank are in the rear undercarriage.
    Thanks much for rescue on that van. I don't need anything right now but anytime we save an oldie, even just parts, a bell rings in van heaven.
    Thanks again, Mark
    Wrong Way
    Wrong Way
    Post by Wrong Way Mon Nov 07, 2011 9:36 am
    I was down there Friday and finnished stripping everything off of it that I missed the Friday before and watched as it went to the crusher R.I.P. Good part is PARTS!
    Dennis
      Current date/time is Tue Nov 19, 2024 5:29 am
