    63 econoline stock wheel size
    63 econoline stock wheel size Empty 63 econoline stock wheel size
    Post by Guest Tue Oct 25, 2011 2:31 am
    All,
    I have stock 13" rims on my econoline and was hoping someone here knows what backspacing, bolt pattern, and width these stock rims are... I'm over seas for the next month and want to order some tires and rims but need to figure these things out. If anyone knows please reply. Thanks
    Number of posts : 2198
    63 econoline stock wheel size Empty Re: 63 econoline stock wheel size
    Post by EconoUSAparts Tue Oct 25, 2011 5:26 pm
    Zero offset, 5 on 4 and 1/2 spacing,and not sure on the width but around 5 and 1/2 inches would be my guess.
    Post by Guest Wed Oct 26, 2011 4:29 pm
    I thought it was 5-4.5 bolt pattern thanks
    Post by EconoUSAparts Wed Oct 26, 2011 5:39 pm
    mattywings wrote:I thought it was 5-4.5 bolt pattern thanks
    It is. That's the same as what I said.
    Number of posts : 648
    Post by Rayallen Thu Nov 03, 2011 2:00 pm
    You do not have to run a zero offset wheel. I think most guys with Econolines do not. Not super easy to find wheels you like with a zero offset. Also you can run 13, 14 or 15" wheels with a 5-4.5 bolt patter.
    Here is a thread I started a little while back when I was trying to figure this out myself
    https://vintage-vans.forumotion.com/t22670-wheels-and-such
      Current date/time is Fri Nov 15, 2024 2:25 am
