    Rear License Plate Location
    Murdock
    Murdock
    Number of posts : 314
    Rear License Plate Location Empty Rear License Plate Location
    Post by Murdock Tue Sep 20, 2011 9:03 pm
    I am scratching my head on this one. I searched the forum and didn't see an answer but perhaps a google image search holds the answer...
    My '67 has the license plate located below the rear doors. A '65 I just saw has it on the rear left door as do the 2nd gen Econos, however a '64 & '63 I saw has it mounted below the doors. Anyone have info on the vintage vs. location? I am guessing my rear left door was swapped out at some point with an earlier one and the PO moved the plate location.
    Rear License Plate Location Empty Re: Rear License Plate Location
    Post by Big W Tue Sep 20, 2011 9:11 pm
    My 67 and my 66 have the plate on driver rear door, with the light for it as well.
    fmc56
    fmc56
    Number of posts : 553
    Post by fmc56 Wed Sep 21, 2011 1:47 am
    All pickups have the plate mounted on the rear bumper, or below the tailgate if they did not come with a rear bumper. 61-64 vans used the same rear bumper as the pickups and the plate mounted there. 65-67 vans had the plate mounted on the left rear door.
    Fred
    Murdock
    Murdock
    Post by Murdock Wed Sep 21, 2011 11:24 am
    Thanks for the replies. The confusing part is that the body on the 65-67 is cut for a lower plate location.
    Number of posts : 437
    Registration date : 2010-12-14
    Post by StuNami Wed Sep 21, 2011 11:34 am
    My 67 is on the bumper. I have the plate light coming through the roll pan and bumper.
    Rear License Plate Location 31309311
    Post by Guest Wed Sep 21, 2011 1:52 pm
    Murdock wrote:Thanks for the replies. The confusing part is that the body on the 65-67 is cut for a lower plate location.
    They are all that way. 65-67 Just has it mounted on the door. 61-64 had it mounted on the bumper if it has a bumper but you can locate it in the middle of the roll pane if you have no bumper 0n the 61-64 and also the 65-67 if you don't want it on the door.
      Current date/time is Fri Nov 22, 2024 1:25 am
