This would get my carb off the side of the doghouse, or push it into it..? It looks like it turns the carb too, maybe bump into the valve cover. Wish I had one to test fit. I guess you could flip it upside down so it goes either way.
Offenhauser #5497 Ram Induction Adapter
This sensational creation by Offenhauser has more than proved itself over the yeras as the easiest and most inexpensive method of giving your engine that RAM effect. These adapters can be bolted on your present set-up, either single or dual quad and then removed for street use if necessary. Made to accomodate most quad carburetors.
Ram adapter measures 4 high and 13-1/2 wide.
