    Intro and help Identifying an axle
    Intro and help Identifying an axle Empty Intro and help Identifying an axle
    Post by Guest Sun Apr 24, 2011 7:48 pm
    Hey all, new to the forum and in search of information. I have a '23 T-bucket hot rod with an all chrysler drive train (383/A-833) and what I'm assuming to be an old Dodge straight axle from a van/truck. My problem is I went to do wheel bearings and discovered the front hub is junk from the inner race spinning in it. Before I do any of the drastic shim/weld/machine/loctite/peen remedies I would really like to at least attempt to get the correct hub, problem is, I'm having trouble identifying the axle. The discard # on the drum is 11.090 (11" brakes?) with a "C10-773". I can't really seem to find anything by googling any of the numbers on the drum. I was told it looks like a modified 64-70 A100 axle....#2200 or #2500? It is 5 lug with a 4.5" bolt circle. I'm really no expert on this and it's been quite perplexing because the weather is starting to turn nice here in WI and I want to get the car back on the road! If anyone can positively Identify this axle or has a hub/drum assembly (or just a hub), I would be more than willing to buy it, or if you have any info on where to get one it would be greatly appreciated. Thank you for your time!
    Pics below:
    Intro and help Identifying an axle 20110423154309463
    Intro and help Identifying an axle 20110423154406712
    Number of posts : 922
    Intro and help Identifying an axle Empty Re: Intro and help Identifying an axle
    Post by wylee Mon Apr 25, 2011 3:19 am
    i could be wrong, the axle dosent look like its from a dodge van..........
    Post by Twinpilot001 Mon Apr 25, 2011 4:11 am
    Maybe a Homeade axle ?? Looks like sq. tube.
    Number of posts : 7905
    Post by DanTheVanMan Mon Apr 25, 2011 6:13 am
    Looks like a custom job to me!!!
    Intro and help Identifying an axle Qr_cod10
    Post by Guest Mon Apr 25, 2011 6:21 am
    Well i think the dropped the axle and filled in the I-beam....either way....any idea what the drum/hub is from?
    Number of posts : 3046
    Post by RodStRace Mon Apr 25, 2011 8:33 am
    This guy came over from the HAMB, so let's help him!
    I too noticed the axle does not look like one of ours, but it could have been filled.
    However, the spindle and backing plate mounting look different too. Does someone have a good comparision shot that shows these details?
    Post by Twinpilot001 Mon Apr 25, 2011 9:01 am
    long ago - many rodders put the old 40 ford spindles & drums on stuff- might look at that??
    Post by RodStRace Mon Apr 25, 2011 9:19 am
    No, they have a T profile to them, and the HAMB guys would have spotted them in seconds
    Intro and help Identifying an axle 816341
    I'm wondering if it's an earlier design; the low mount of the steering arm, the cast in steering stop instead of the bolt like the A-100, the brake hose over the top of the spindle.... I'm just going by memory here
    Post by Guest Mon Apr 25, 2011 10:46 am
    thanks for all the help so far guys! The guy at napa said it could be a dodge P100 or P200....not sure theres a difference?
    Post by Guest Mon Apr 25, 2011 11:36 am
    Ok guys...i may have found an answer....a friend of mine who items a parts store said the number on the drum references a 59-69 2wd d100 pickup..should be easier to find
    Number of posts : 1319
    Post by 67a 100 pickup Mon Apr 25, 2011 1:57 pm
    OK.. here ya go.... looks like a D-100 axle from the pics in my parts book
    Intro and help Identifying an axle Dsc_0120
    Intro and help Identifying an axle Dsc_0121
    Intro and help Identifying an axle Dsc_0122
    here is a like to one on ebay
    http://cgi.ebay.com/ebaymotors/1965-D-100-Dodge-Truck-Front-Wheel-Hub-_W0QQcmdZViewItemQQhashZitem3cb72f8414QQitemZ260771382292QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
    I talked to my napa guy and there are a few new drums in the system if you need one, their part number is 440-1749 279.5 mm= 11 in.
    Post by Guest Mon Apr 25, 2011 5:22 pm
    67a 100 pickup wrote:OK.. here ya go.... looks like a D-100 axle from the pics in my parts book
    Thanx! Very useful info.......i called a local junkyard here that deals with 65 & older and they have one.....going to pick it up tomorrow. Once again, thanks for all your help.
    Number of posts : 8769
    Post by dix Mon Apr 25, 2011 7:09 pm
    KIND OF READ THIS A BIT LATE BUT THESE GUYS CAN HELP http://www.sweptline.org/forums/index.php
      Current date/time is Fri Nov 15, 2024 5:08 am
