Here is the start. Started on the left side. Had to heat the knuckle to remove the drag link. Set pin seized in the axle. Drill out the set pin, not too bad. Then the king pin was seized. Beat for a bit. Cut it in to three pieces with the cut-off wheel. Then to stat drill out the pin. Drill, drill, drill.
6:45 am now. Been a long night of seized pins. Heat, drill, heat, drill, drill, beat, beat, beat. Still, I'll do it again when I get another. toad
