If a person had a 700r4 laying around and wanted to pull the 3 speed manuel trans of his 250 strait 6. What would be the check list for a swap like this?
What does it take to install a 700r4 on a 250
m1dadio- Chevy Guru
- Number of posts : 1778
Starter ring gear flex plate
Trans cross member and mount
TCC wiring inside and outside of trans
Shift linkage
Shift indicater
nutral saftey switch
revers lights?
drive shaft and yoke
Speedometer conection and gearing
Trans cooler and lines
That will get you started
M1D
Shift linkage
Shift indicater
revers lights?
M1D
