by EconoUSAparts Wed May 04, 2011 9:37 am
I posted this a few days back in another thread. Carl hasnt responded yet;
>>>> Carl,have you installed yours yet? Kris and I were messing with the ones I have here today. While they do look nice,they dont fit exactly correct. The corners are slightly off and it will take some work to make them fit flush against the dash like Vic said. The upper edge is a little off so Vic used bondo to make the one he used look nicer. The end curves are going to be the hard part to deal with as the skirt itself seems to be about 1/4 inch too long,leaving gaps in each corner. Additionally Im thinking about 1/8 inch needs to be trimmed off each end lip,which the lip in itself wont be a problem but the gaps will be for the perfectionists in the crowd. This is not just a direct bolt on and forget it propduct. It will require some work to get it to fit.
