Does anyone have pictures or a step by step guide on how to put a chevy radiator back in a 1966?
Sportvan Radiator
1966G10- Number of posts : 138
Registration date : 2009-10-14
Sportvan Radiator
Re: Sportvan Radiator
Well it comes out the bottom,,,,,,,you remove the bellypan,,,,, undo the hoses, and transmission lines if you have them,,,,,remove the bolts under the passenger seat going into the radiator,,,,remove the bolts under the van that are on the side of the radiator on the drivers side,,,,,,,,if you have a sway bar, take it off or jack the van way up to slide the radiator out towards the front.
