+5
9 posters
First gen master cyl plug
Has anyone come up with something that will replace the stock floor plug on a first gen that most of us are missing
- Number of posts : 8729
Re: First gen master cyl plug
can you post a photo???. i'll try to help.
m1dadio- Chevy Guru
- Number of posts : 1778
What about the ones for the PU trucks from the late 40's and early 50's?
They are availible as reproductions from the PU repo parts companys as well as the door seal people.
Has anyone tryed one of those?
M1D
M1D
Thanks Don for the picture (I've never seen one)
M1D I'm guess or hoping it's one of those GM parts that has been used from another year
I need one also !! 55-59 Chevy are to small=3 1/2" OD. Will probably have to make it from hydrent washer.
Its pretty tough working with a dual MC cover out of that little hole ??
I'm sure it will be a hassle
There is enough room down there to get the dual master cylinder cover off through that hole,,,,,,
I got a single MC on my 64 with the clamp on lid ,it a Major pain to get the lid off with the shifter rods on both sides
Those rods are the least of your worrys if you still got a single line master cylinder
Try the repo companies for pickups -same
The dual master cylinder is about 1" narrower than the single line master cylinder,,,,,,,,,,so Tommy,,,,,,,now you got a good reason to get rid of that single line system,,,,,,,
DanTheVanMan- Commissioner
- Number of posts : 7900
Thinking you could just put in a Marine access hatch. Here's a 8" that would work fine even with a double pumper...
http://www.boatersworld.com/product/MP80814237.htm
That's a good idea Dan, I had a idea myself going to check to see if they make a ductwork 4" cap???
Want me to cut ya out some circles from plate steel? Its easy enough to make the basic shape , the hard part is making something that would snap in and seal tight. I can layer 2 pieces so it doesnt move much in the hole?
- Post n°19
Joe Let check at the heating and cooling supply first, but I might take you up on your offer. I really would like to find something we all can use that a simple mod
Don that also is a good idea
- Post n°20
I spilt my opening and moved half of it back and filled in the sides and made an oblong hole, then just set a piece of plate in it. but my floor was a mess anyway and it didnt bother me hacking it up some..LOL
Ok Chris , the offer is there if you need it.
m1dadio- Chevy Guru
- Post n°21
Thats a good idea Don!
M1D
M1D
- Post n°22
checked with the heating supply warehouse today no luck, going to check the pipe supply warehouse Wedsday.
