kcvanner
    dim gen light
    kcvanner
    Number of posts : 4
    Registration date : 2010-06-24
    dim gen  light  Empty dim gen light
    Post by kcvanner Sat Jan 29, 2011 8:58 am
    I've replaced the gen, reg, and battery..light is dim before and after starting the van.
    any ideas?
    Number of posts : 7905
    dim gen  light  Empty Re: dim gen light
    Post by DanTheVanMan Sat Jan 29, 2011 10:15 am
    Sounds like a Wiring issue...
    dim gen  light  Qr_cod10
    Eagle1
    Eagle1
    Number of posts : 144
    Registration date : 2010-09-18
    Post by Eagle1 Sat Jan 29, 2011 11:18 am
    kcvanner,
    I had the same problem, i redid the ground from the battery to the motor and added one to the body and it went out! poor connection.
    Eagle1
    Number of posts : 12247
    Post by donivan65 Sat Jan 29, 2011 12:14 pm
    Run a jumper from the voltage regulator body to the doghouse,,,,,see if that helps,,,,,,,,do you know what the voltage reading at the battery is?
    kcvanner
    Number of posts : 4
    Post by kcvanner Sat Jan 29, 2011 1:17 pm
    ok, switched over ot the one wire alt...I have a short..11.93 on the voltmeter...what is the best way to locate it?
    thanks for the help
    Post by Twinpilot001 Sat Jan 29, 2011 1:31 pm
    pull the fuses 1 by 1 till it is located.
    Post by Twinpilot001 Sat Jan 29, 2011 1:32 pm
    also disconnect the alternator & see if it quits?? If so the alt is bad internally -bad diode set discharging the batt.
    Number of posts : 1778
    Post by m1dadio Sat Jan 29, 2011 3:33 pm
    What twinpilot001 said!
    That ia usualy a shorted diode in the alternator, And it will drain the battery.
    M1D
    Post by Twinpilot001 Sat Jan 29, 2011 4:36 pm
    and I dont mean the engine will quit! just the current drain - You can also do same in the dark to see if the alternator sparks a small amount -indicating the current draw on the system thru the alternator - do this as engine isnt running- if you see a spark in the dark - the alt - diode trio is bad - which can be replaced easily.
    Post by donivan65 Sat Jan 29, 2011 8:44 pm
    If you mix up the 1 and 2 wires on a 3rd gen alternator, you will cause a drain on the battery,,,,,
    dim gen  light  3rd_ge10
    Post by Twinpilot001 Sun Jan 30, 2011 5:01 am
    Good Info!! Yet -I thought the new alt was a 1 wire?? Only diff was a diff rectirier.if my old memory is still workin?
    Post by donivan65 Sun Jan 30, 2011 8:25 am
    The 3rd Gen alternator is a way cheaper and better way to go if you want to get rid of the mechanical voltage regulator,,,,,,,those 1 wires regulate the voltage from the output of the alternator, I like it better with the 3rd Gen one since you can connect the #2 terminal to a place near the battery so the battery regulates exactly what it needs. and,,,,,,,,I have found those #1 and 2 wires hooked up backwards on many conversions which will work,,, but it causes a drain on the battery,,,,,,,,
    Post by donivan65 Sun Jan 30, 2011 2:34 pm
    But getting back to your drain,,,,,,,11.93 volts don't mean nothing,,,,,that could be just a milliamp,,,,,,AMPS is what matters and the easiest test is to undo a battery cable, put a 12 volt test light between the cable and the post and if it lights up,,,,,,you gots a problem,,,,,,,it takes about a 1/2 amp flowing out of the battery to cause the test light to light up so if it does during this test,,,,,,something is using it and will kill the battery. So if it's on, start unplugging stuff like the guys just said until you make the light go out. Then you have found the cause.
    dim gen  light  Draine10
    Post by m1dadio Mon Feb 07, 2011 10:10 pm
    What Don said.
    M1D
      Current date/time is Sun Nov 24, 2024 5:23 pm
