Ok I am looking for info on how or were I can connect my throttle lever from my 727 to my 2 barrel carb? I have switched over to a VW style throttle cable and do not know how the throttle lever works in relation to the shift linkage. Any ideas?
Throttle Shifter Lever/rod ?
kltcustoms- Number of posts : 199
Registration date : 2008-07-07
Re: Throttle Shifter Lever/rod ?
That is perfect..thanks for the page but what does it do? I mean does it move in and out with the throttle? Is the V-8 and 6 the same basic thing, both go to the carb and attach right?
jkr- Number of posts : 1148
the throttle linkage should move all the linkages in sequence to apply "kickdown" to the trans. it does it by changing pressure through the valve body and in relation with the governer that is located on the tailshaft. it also makes the trans shift down or up based on the same principals, speed and hydraulic pressure.hard to explain and even harder to understand unless your a transmission repair person but the adjustment is a very important item.
heres what you need to do, based on the pic above;
hold the transmission throttle lever towards the rear as far as it will go
take your gas pedal and push it to the floor (engine not running)
there should be just a slight gap at the carb where the linkage goes towards the rear on the throttle rod.
not enough your throttle won't open all the way,
to much and your shift points will be off based on line pressure.
that pic shows a ball joint at the carb linkage but i am sure there will be a slotted piece there and it is adjustable. that actually looks like a v-8 linkage on an older car as some of our vans and pickups had a one piece setup from the factory and only one place at the carb for adjustments. i know this because mine came with the one piece and i changed it over to a 273 dart style like in the picture.after three years or so of trying to get mine to work properly i fixed it with a transmission swap and complete linkage swap. i had a friend use parts from three different cases to build my first trans but did not realize the governors and valve bodies were not compatible and neither did he. there was an internall pressure problem and thats why mine never shifted right till i changed to a 1977 transmission that i got complete and rebuilt myself. live and learn.
the adjustment is very important to make your trans shift up at the correct time and backshift. to tight and the shift is late and harsh, to loose and the shift is quick and the vehicle is in drive to soon and burns clutches.
hope this helps a bit........ good luck
If you can't source a complete linkage, you can buy a Lokar or other setup.
Here's an example.
http://www.bouchillonperformance.com/BPEtkdc.asp
Just make darn sure you follow instructions and set it up properly. It is not something to rush through or do "good enough"!
Here's an example.
