    CRAGAR S/S WHEELS UNILUG Who's in the know?
    Number of posts : 864
    CRAGAR S/S WHEELS UNILUG Who's in the know? Empty CRAGAR S/S WHEELS UNILUG Who's in the know?
    Post by Casimier Wed Dec 15, 2010 6:01 am
    Just got some 6" x 14" uni-lug cragar s/s wheels for the vickup. They are marked on the back 4.5 and 4.75 and they have that race track shaped bolt hole?
    ? No. 1 Will they fit?
    ? No. 2 What lug nuts and washers do I use? 1/2"-20 lugs with Cragar Offset washers?
    ? No. 3 Do they make a lock/lug for these wheels?
    ? No. 4 What P size tire looks best? I'd like to go with a wide low profile tire like the radial T/A's. Just don't know the best fit.
    Here's a pic of the LOOK I was lookin for....old pic from Ebay
    just that the wheels are not wide enough....
    ....CRAGAR S/S WHEELS UNILUG Who's in the know? DSC01613
    Any help is appreciated.
    Thanks
    Jim
    CRAGAR S/S WHEELS UNILUG Who's in the know? Empty Re: CRAGAR S/S WHEELS UNILUG Who's in the know?
    Post by Twinpilot001 Wed Dec 15, 2010 6:05 am
    Hi - should fit - did u get the race track=( Unilug_ spacers? yes there are locking lugs available.
    Post by Casimier Wed Dec 15, 2010 6:21 am
    ? do these washers actually fit inside the race holes or do they sit on top of the wheel ?
    no, I did not get the lugs or washers...
    Number of posts : 7905
    Post by DanTheVanMan Wed Dec 15, 2010 6:40 am
    Jim, the washers "do" fit inside the indents "Race tracks".
    Washers:
    http://cgi.ebay.com/ebaymotors/Cragar-KW225-1-Chrome-1-2-Offset-Oval-Washer-1-pkg-_W0QQcmdZViewItemQQhashZitem483dd05fbeQQitemZ310274711486QQptZOtherQ5fVehicleQ5fParts
    Lugs:
    Without seeing the wheels it's hard to tell exactly which lugs you will need (SHANK MAG STYLE ?/STANDARD ACORN? Depending on exactly which Cragers they are), but here's a good place to search once you have the wheels.
    http://shop.ebay.com/i.html?_nkw=Cragar+lug+nuts&_sacat=0&_odkw=Cragar+Offset+washers&_osacat=0&_trksid=p3286.c0.m270.l1313
    Tires:
    In my opinion 195-225/65's in front and as much meat under the rear as you can fit!
    But in your case if all four are 6" wheels then your slightly limited on sizes.
    Here are the safe recommended sizes for that wheel size:
    195/60 14
    195/55 14
    205/60 14
    205/55 14
    215/55 14
    Also keep in mind they are 14" wheels. Tire selection may be limited.
    Personally I would go with 195/60 on the front and 215/55 on back. (My Opinion Only)
    Hope this helps,
    Dan
    CRAGAR S/S WHEELS UNILUG Who's in the know? Qr_cod10
    Post by Casimier Wed Dec 15, 2010 7:01 am
    Hey Dan and twinpilot
    thanks for the help...
    ? if the racetrack bore is only 5/8" wide, how does a washer which looks about a 1" outside dia. fit inside?
    Does the washer have an indent or sleeve for the racetrack hole?
    Post by Twinpilot001 Wed Dec 15, 2010 7:11 am
    Yes it will also these were patented orig. by cragar i believe - also some otehrs mfg's used them -yet wernt many. The name was =UNILUG= and you should be able to get some from a speed shop or actually wheel & tire stores.Ive got 2-3 sets of wheels on my vehicles here of that type. Orig mfg . in the 70's-on. I would think the set of wheels u r lookin at would have them with them?/ Unless the seller bought new wheels & not the lug nut kits?"
    Post by DanTheVanMan Wed Dec 15, 2010 7:12 am
    Casimier wrote: if the racetrack bore is only 5/8" wide, how does a washer which looks about a 1" outside dia. fit inside?
    Most unilug washers are universal. But measure your stud hole, width & length of your Indent "exactly" and we can help find you the correct ones...
    And if you can. A couple of good closeup pic's would really help. And the wheel model if you know it.
    Dan
    Post by Twinpilot001 Wed Dec 15, 2010 7:13 am
    Post by Twinpilot001 Wed Dec 15, 2010 7:14 am
    Post by Twinpilot001 Wed Dec 15, 2010 7:15 am
    Back in the late 60's and 70's we bought them under the ET brand & then cragar i think bought them out with the patent
    Post by Digz Wed Dec 15, 2010 1:37 pm
    Theres an Ebay store under LUGNUT KING, they have about everything, I have used them several times. Summit has an assortment of 14" tires in the Mickey Thompsons also I believe.
    Number of posts : 3046
    Post by RodStRace Thu Dec 16, 2010 7:20 am
    I went to the local tire store and showed them the wheels. In fact, I left them there so they could measure as needed.
    The washer fits into the notch in the face of the wheel, and the lugnut fits into the hole. The washer does not go in the hole.
    They were able to get the right washers and lub nuts (even left hand thread for the Dodge) after 2 tries. Make sure to test fit the washer and lugnut in the wheel to make sure the end of the nut does not extend past the face of the wheel. It would be a good idea to bring in one lug nut that fits the van so they are sure of the thread size.
    kookykrispy
    kookykrispy
    Number of posts : 1533
    Post by kookykrispy Fri Dec 17, 2010 3:58 pm
    Ford and Dodge musclecar or early van uses the smaller 5 x 4&1/2" pattern, so use the offset washers with the hole to the inside of the wheel to mount the Cragar S/S unilug wheels.
    Tire size... you are limited because of the 6" width.
    Make sure to follow tire sizes recommended for the 6" width of your wheel:
    http://customwheelsmarket.com/rimwheelwidth1.html
    Here is a link that can give you dimensions for any size tire:
    http://www.discounttire.com/dtcs/infoTireMath.dos
    For 14x6, I would say the max tire size is probably 225/60r14
    Lugs nuts: For cragar S/S wheels, you want the medium (approx. 3/4" long) shank mag style lug nut. I think your econo is 1/2 x 20 thread pitch, but double check on that, I'm not a ford guy.
    Cragar S/S 15's on my '64:
    CRAGAR S/S WHEELS UNILUG Who's in the know? DSC07318
      Current date/time is Tue Nov 26, 2024 12:17 am
