got my daily driver home from florida this week and have a couple questions if anyone can help.first it handles like a washtub-pretty hard to keep it in a straght line.the other thing is the speedometer.the needles bouncing all over.ill be doing somewhere between 40 and 50(who knows-it feels like im doing 160).anyone have any advice,tips or some knowledge of this.thanx,sonny
some help with new 67 econoline
sonnygable- Number of posts : 90
Registration date : 2008-09-03
jreese- Number of posts : 26
Re: some help with new 67 econoline
sonny
Not sure on the econoline, but my Mustang handled just like that when I got it. I replaced shocks, all rubber and joints up front and added a large sway bar. It handles like it is on rails now. Not sure that helps but the handling sounds much the same.
Jim
Jim
- Number of posts : 12245
Look at the front tires and see if they are wearing funny,,,,then jack up the front end and see if the front tires have any play in them,,,up and down, in and out, side to side. See if anything seems loose. You could have worn tie rods and king pins. Then check the toe in,,,,see if the measurement between the front of those tires is about the same as the rear,,,,,you want those front tires parallel to take the van straight down the road. Rock the steering wheel back and forth to see if there is a lot of play in it,,,,,,
Regarding the speedometer, the cable could be bad. I don't know if they make new ones the your, but you may be able to take it apart, clean it up, and reassemble using ATF or some other lube.
