it appears my turn signal switch is shorting inside the column. my whole turn assembly is loose and it appears the part below the white plastic signal cam which has wires leading in to it is the culprit. as it is, my signals will work, but if i jiggle the wires in this piece, they will stop working or the pass.brake light goes out, jiggle and it works again. I am not sure if this is part of the wiring harness? down to the fuse box or is this a separate part of the turn switch that can be replaced. I have tried to find a drawing of the assembly without any luck.
any ideas?
thx in advance
any ideas?
thx in advance
